Custom trike help!!!!
Lucasmarine
Hey guys, I'm obviously new here. So here's some background on what I have going on.
About 4 months ago, I bought a home built trike on Craigslist. It was a combination of baha forks and a home made frame and rear end. It came with a 5.5 hp Tecumseh engine. Well I ran it for a month or so and wore out the bearings and it became rather unsafe to drive. So, I did what any red blooded American would do. I decided to make it bigger better faster.
I picked up a Honda gx340 for 40 beans. It ran when I bought it, but I knew it had more potential.so I bought the stage 1 hop up kit, changed the springs and advanced the timing 6*. Got a 32mm mikuni slide carb and intake manifold. I had to change the crank from the tapered shaft to the solid shaft, so while I was in there I replaced the piston rings and removed the governor. Got it all back together and timed and it screams. Got a 14 tooth 1" heavy duty centrifugal clutch and a 40# chain.
On to the frame.
I did some small modifications to the frame to allow for two things, 1. Was a fork/triple tree setup from a ttr125 Yamaha. Second was the read end. Originally it had a 3/4" drive shaft, I beefed that up to a 1". Mounted a 60 tooth rear sprocket and a big disk brake to the rear shaft, complete with a suicide brake handle mounted directly between my legs. And go it rolling on some 24"x12" atv mud grippers out back, And a 19" dirt bike front tire.
Soooooo. All that said. After I got it all together, got it started and running, I took it for a spin. First thing I notice is the TOTAL LACK of acceleration. After a bit it'll get up and go, but off the line it's got nothing. Second thing is that the clutch was smoke ked. As in red glowing hot. So my question is,
What should I use that won't smoke my clutch, and what can I do to improve acceleration?
Bbqjoe
Banned
Location, Location
Or look into a torque converter
Probably going to need at least 7:1 ratio.... but your going to need a jackshaft... At least you have some space to fit it.....
If your clutch is fine(which it might not be)...
A 14t(clutch), 24t JS in- (a 12t to16t will bring good ratio to start)out, 60t rear end.
Here is a good calc to find ratio's to use...
http://www.affordablegokarts.com/GearCalc.php
