Done Felled off the Wagon
My 212 with 390 carb has fallen off the wagon.
So after some biased research - I found that I can probably run methanol with 11:1 CR and 32 BTDC ignition timing. This is probably the minimum CR and least amount of advance I feel comfortable with. Just so happens I have 11:1 CR and 32* ignition timing.:cheers2:
So I took out the idle jet from the 212cc carb. Fortunately it also fits in the 390cc carb. This is going to get "bored to death" - or maybe just to 0.8mm (0.0315").
The main jet will be #160 from NR (1.60mm) 0.063".
I want to run 20% Nitro RC Fuel.
It looks like it has 14% oil to go along with 20% nitromethane.
I know it will work, but is this terrible for the 4 stroke engine?
I'm aware that most who run alky will clean the carb and lines by running gas afterwards.
What is a better option and where can I find it?
I'm only looking to get a gallon for testing purposes.
Don't really want to spend more than $30.
Any ideas?
Bbqjoe
Banned
Location, Location
Any ideas?
I'm certain there's a number of full blown alcoholics here who will burn for days, if not weeks, when cremated.
Maybe you can get just a few pints of blood from each. :D
Trying to hand twist the 0.5mm bit into the stock 212cc carb idle jet has gotten me no where except three beers deep into a bucket.
I figured by the time I finished the wings I'd be done.
Alcohol impaires judgment.
Funny how I need less bit to get more jet.
You confused me. Are you going to run nitro methane or methyl alcohol. Two different things.
My dad runs a methyl alcohol dragster. I know a little.
It's corrosive to aluminum! Hence the gas flush.
Now nitro methane is liquid dynamite.
Please tell me your gonna run nitro!!!!!
RC Fuel.
It says 99% Pure anhydrous Methanol,
14% Oil (castor or castor/synthetic mix),
20% Nitromethane.
Something Like this ...
http://www.rccaraction.com/blog/2015/09/22/everything-you-need-to-know-about-nitro-fuel/
---------- Post added at 06:30 PM ---------- Previous post was at 06:29 PM ----------
WHAT’S IN IT?
Every container of nitro car fuel you’ll see at your hobby shop has the same base set of components. The proportions of each compound varies from manufacturer to manufacturer and within a company’s products lines depending on application, but you can always count on these three essential ingredients:
• Methanol
• Nitromethane
• Lubricants
METHANOL
Methanol, the largest component of nitro fuel, is that part of the fuel that burns. It’s a simple compound made of carbon, oxygen, and hydrogen atoms. Methanol can burn in air, even without the other components in nitro fuel. An important thing to remember about methanol is that it is hygroscopic, meaning that it absorbs moisture from the air. This is the reason that it is so important to keep fuel containers tightly sealed. If you don’t, moisture in the air will be drawn into the fuel, causing it to spoil.
Byron Fuels Everything You Need to Know About Nitro - nitro content
The higher the nitro content as shown at the top of this Byron Fuels bottle, the greater the power and rpm–but operating temperature goes up too.
NITROMETHANE
Nitromethane is a simple compound, consisting of carbon, hydrogen, oxygen, and nitrogen atoms. That’s right — the “nitro” is from nitrogen, which is what air is mostly made of (not oxygen, as commonly believed). Nitromethane is flammable on its own, even without oxygen, but it has a very high burning point—well over 4,000 degrees Fahrenheit. When mixed with methanol, nitromethane acts as a catalyst, increasing the burn rate of the fuel blend to produce more power. The more nitromethane that is used in the fuel blend, the faster the fuel can burn, letting the engine run at higher rpm. The big percentage number you see on a bottle of fuel is its nitro content, which generally ranges from 10-40%. For all-around use, 20% nitro is the most popular choice. Nitrometane and methanol are sourced by fuel makers rather than manufactured, so different brands don’t lay claim to unique or better nitrometane and metanol. However, the conditions in which these materials are stored and mixed greatly affects fuel quality. Byron Originals fuel blending facilities were designed and built solely for the production of model engine fuel and use processes engineered to assure high quality is maintained throughout the manufacturing process.
Byron Fuels Everything You Need to Know About Nitro - castor beans
Castor oil comes from these guys: castor beans.
LUBRICANTS
Lubricants are an integral part of nitro fuel recipes, since our 2-stroke engines don’t have oil-filled crankcases and instead rely on lubricants mixed into the fuel to keep the internals running smoothly. Since early days of fuel-powered models in the mid-20th century, oil from the castor bean has been used as a lubricant in nitro fuel. It is resistant to breaking down at high temperatures, a desired quality in a 2-stroke fuel. However, it can leave a gummy residue. Byron Fuels developed a castor oil that provides superior lubrication yet does not leave the negative byproducts of standard castor oils. Byron Fuels use a blend of natural castor and synthetic oils in their fuels, although there are a few pure synthetic blends available. Byron Synthetic is a proprietary lubricant package with fortifications in both corrosion protection and high pressure lubrication (load carrying capacity). Only Byron Fuels contain this superior synthetic formulation. The percentage of lubricant in the blend depends on the purpose of the fuel; premium race fuels have less lubricant, typically in the 8-12% range, than fuels designed for engine longevity, which can consist of upwards of 20% lubricant. The reason for this is that with less lubricant in the blend, there can be more methanol, which makes for a more powerful combustion process, but with increased engine wear. Racers will gladly sacrifice piston and sleeve life for greater performance, but if you want your engine to last longer between rebuilds, choose a blend with a higher percentage of lubricant.
Joe-405
Enjoying New Projects
U.S.A.
RC fuel is bad. Too much oil it fouls plugs fast.
110 octane or if you want the same power as alcohol but don't have to flush it use q16. You have to add 20% more fuel with the q16. Its pricier than 110 but you'll thank me later !
Hmmmm... Didn't think about that.
I'll have to look up q16. Does it have extra oxygen?
Who knows about E85?
---------- Post added at 06:51 PM ---------- Previous post was at 06:50 PM ----------
And will I need the fuel pump?
Itty bitty bits.
My bits got a tid ittier.
0.016" and 0.018"
Trying to plug a cool store but my camera only focuses in one direction.
Go Cubs.
0.032" Idle.
0.063" Main.
Finished. I guess I should have pressed harder but didn't want to break the iddy bit in the brass insert.
Staff Murderator
Yeah, nitro RC fuel is 2-stroke fuel, so it has it's own lube blended in.
I've read about someone doing it though. Was it FreeRunner?
http://www.dragzine.com/tech-storie...tory-of-16-vp-racing-fuels-x16-vs-c16-vs-q16/
Q16 IS Oxygenated!!!!!
---------- Post added at 09:29 PM ---------- Previous post was at 09:28 PM ----------
Q16: Bringin’ the Air
Here’s where you really start making power. The Q16 is an oxygenated fuel, so it brings the air with it. It’s like C16 and X16 on nitrous, since it brings its own atmosphere to the party. Q16 will work well in any drag racing application, but it will require increased fuel flow because of the extra air being introduced into the intake system. You will know Q16 by its yellow hue.
According to VP, Q16’s oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won’t vary as dramatically with altitude or density changes.
One customer who can back up those claims is NMCA racer Dan Baumann. Baumann races in Xtreme Street in a Fox body Mustang with a small-block Ford engine and a ProCharger. Already a competitive car in the class, Baumann made the switch over to Q16, and with no other changes, his combination made 40 extra horsepower. A couple degrees and a timing curve adjustment had total improvement at 60 horsepower, just by draining the car’s C16 and adding Q16. In all, Baumann made 20 dyno pulls in one day, and the Q16 helped his combination make the power he knew it should.
This is a drag racer’s dream to see this much race fuel in one place. VP is at many of the larger drag races with displays like these, and with fuel for sale.
As for Rueckert’s opinion of Q16, he’s pretty adamant with his thoughts.
“If you’re allowed to run it, Q16 is the fuel you want to run,” he says. “There’s no cheaper way to make horsepower.”
VP bills Q16 as a performance part, much like actual engine components. “There’s nothing that any other company manufactures that will make the power that’s possible with Q16,” Rueckert adds. “Steve Burns and I got together, and Burns had this chemical in his back pocket, and he thought it was time to bring Q16 to market,” Rueckert adds.
The guys knew oxygenated fuels were popular in the motorcycle market, but hadn’t really caught on with the automotive market. They thought it was time to change that, so they brought Q16 to market and introduced it to racers. Rueckert says he gave Q16 to Steve Petty back when it was introduced, and with a turbocharged big-block combination, the fuel helped pick up more than 100 horsepower alone.
Since it is oxygenated, Q16 will need 4-8% percent more fuel volume. “It’s going to run leaner right off the get go,” Rueckert says. Many of the popular engine management systems on the market are able to compensate for the extra fuel by the user adding that percentage to the fuel mixture. Or, as Rueckert says, some EFI systems feature a stoic metrical equation they use to calculate a particular combination’s fuel needs. Using that equation, the system then calculates and delivers the precise amount of fuel.
Then there’s Q16, and this might determine if Q16 becomes a part of your drag racing program. For Q16, a 5-gallon pail is $97.25. A 15-gallon drum is $306.19, a 30-gallon drum is $584.78, and a 54-gallon drum is $989.72.
So I got a gallon of 20% O'Donnell Speed Blend.
8% castor/synthetic oil.
It is the lowest oil content I found.
Luckily Hobbytown USA had it.
The only thing I did was change the jetting.
Let's see if it runs?
Jfive
Great falls Montana
Could use low lead 104 fuel from an airport. To bad there's no E85 carbs for small engines or is there? Uses about 15-30% more fuel than just gas alone and has cooling factor and 105 octane assuming its actually 85% not 70% winter blend.
---------- Post added at 11:34 AM ---------- Previous post was at 11:32 AM ----------
Maybe small engine propane conversion. Can run up to 11.5:1 with propane.
I really want the most oxygen in the fuel. I feel that is the easiest way to get more power without raising compression or changing timing.
Now to get the full benefit, I'd raise the compression by milling another 0.010" off the head and advance the timing another couple of degrees.
For now, this is just a test to see if the jetting and fuel alone will make a difference.
I will go back to 100 octane to prolong the life of the engine. I might see if I can run 93.
“Gas is for washin’ parts. Alcohol is for drinking. Nitro is for racin’!” -Anonymous Racer
---------- Post added at 12:22 PM ---------- Previous post was at 12:06 PM ----------
I went to go change the jets in the carb and looked to find a full tank. Thats like $8 worth of 100 octane.
Since my Nitro experiment has the potential to destroy the engine, I think I want to get some riding in before I try it.
I want to find a place to go for a long cruise but not confident enough to get more than a few miles from home base. Something always breaks. LOL Hmmmm. Lets see.
