Well, my engine blew up
ultralight01
Senior Yet Young Member
Hood River, OR, In a galaxy far far away
Title says it all. Was going top speed when my engine failed last night, drifting in a rainy parking lot. There is now no resistance when I pull the cord, but I hear parts moving.
The engine is running at the correct fuel/air ratio now, but when I was running it too lean before, the engine overheated several times. My guess is that it probably warped the valve rockers causing the push rods to fall out. HOPEFULLY it's just that... or something worse happened. No holes in the case that I can see.
I'll update later when I tear this thing apart. Open to suggestions of any kind.
Stupid honda clones not meant for a measly 7000rpm! :2guns:
Staff Murderator
Take it apart and assess the whole situation. All you can do (don't forget photo documentation).
Any catastrophic sounds to go with the failure?
Also, if nothing was forcefully ejected from the engine block, it wasn't a blow up. Sorry dude, no trophy.
Flyinhillbilly
The great cornholio
North West Arkansas
Man, you're tough on your blow up standards. I made a pass in my car one night that costed me just over $7/ft, which don't sound too bad until you figure I was going 1320ft. Nothing came out of the block except water, oil, and fire so I guess I didn't really blow it up although the crank and rods were the only useable parts left.
Sorry to hear about your engine UL, it's an opportunity to learn all about engines in disguise though.
ultralight01
They can be grenaded on the inside... which would cause them to die. :p
My dad has "blown up" thousands of dollars worth of foreign transmissions and engines. Order some special foreign car, put a racing engine in it, next thing you know the transmission explodes internally. Things like that would happen over an over till he was tired of wasting thousands and got addicted to Ariel atoms.
Staff Murderator
YES!
It's... it's...beautiful!
My standards are high, I know it... Can you find it in your heart to forgive me?
ultralight01
Hellion, my trophy please. Lol
So. Stock billet rod exploded. Left a hole in the block. My options are:
1. Buy are billet rod, weld block shut. Say nothing ever happened, race on.
2. Sell engine parts. Buy a motorcycle engine off of Craigslist. Go fast.
This kart was in Craigslist, due to it being winter and me wanting to go to the trails with a dirt bike or small buggy. Now I've gotta make some descisions.
What would you do?
Staff Murderator
Here's your trophy! Congrats!
So is it the billet rod or not? Photos of what's left of the rod, man. Shocking.
EDIT: didn't see what you posted. So it's the stock rod...and that's not "billet". It's just cast aluminum. There's some debate as to whether billet is forged aluminum or not. Hmm.
I'd say salvage what you can but if it's just a small hole... I wonder if that could be welded up? :D
Staff Murderator
I'm left scratching my head and I feel a bit uninformed. Why was it that you were running a stock con rod in an ungoverned, hopped-up engine?
I feel uninformed because I don't recollect this engine of yours having been assessed, built, dissected or made known to the forum as to its suitability for the revs that ultimately caused its failure.
Was this an unverified Craigslist purchase that you took to the limit? "This kart was in Craigslist" doesn't make much sense.
ultralight01
I bought this engine from a factory that builds racing parts. They assembled this engine and sold it to me, saying it had an arc aluminum connecting rod.
It was for sale, by me, as of a few hours ago, on Craigslist. I was selling it to get an off road vehicle, but it looks like I'm stuck with this guy for a bit.
Oh, it most definitely is not ARC... I grew up in memphis, TN, man. Best BBQ in the world...
I was kidding about A1. I only put it in my bloody marys.
---------- Post added at 03:03 PM ---------- Previous post was at 02:58 PM ----------
Even with the ARC Billet Connecting Rods it is recommended to do maintenance. Every so often you need to change the bearing inserts.
Racers do this every 6 races or so (from what i read). Along with changing the oil after every race.
I have a Hemi Block that I have no plans for.
I paid $40 or $45 IIRC. Bought it when I snapped a head bolt but never needed it.
ultralight01
A1 in a Mary? :ack2::smiley_omg:
Yeah, everything needs maintenance...
Staff Murderator
Maybe next time you put up something for sale, you won't jinx it by continuing to use it, Obi-Wan. :p
It doesn't have to be ARC to be good...but it doesn't as yet appear to have the glitzy or crisp looks of a typical aftermarket performance part.
ultralight01
Hey. Before I was selling it it was running way too lean. I needed to make sure I adjusted the fuel ratio correctly. So, test drive and BOOM, smoke pouring out of an engine in the middle of the night in a wet parking lot with a headlight secured to my motorcycle helmet.
Staff Murderator
Well, you win some you lose some. Happens to the best of us but just chalk it up to an experience (whee!), earned experience (wisdom) and lessons learned.
The rod journal appears to have a bit of scoring. Not sure when that occurred in the engine's life cycle but that usually points to an imminent failure (or something amiss).
