Kandi 110cc GKA-2 won't start
gjordon59
I've got a used Kandi 110cc GKA-2 that won't start. I purchased it knowing it wouldn't start but have some knowledge of this kart. In checking the carb, I found it to be corroded beyond trying to repair. So far, I've installed a new carb, drained and put in fresh gas, checked for spark (which appears fine) and has good compression. Given all that, it should run or at least pop but I get nothing. I can't find any useful documentation so is there anything I am missing? I've read some about adjusting the valves but haven't tackled that yet.
Any guidance would be extremely appreciated!
Completely clueless on that 110cc...but..just going by engine 101...shoot starting fluid, carb cleaner, or brake cleaner in the carb throat...if it runs for a few seconds...you still have a fuel delivery problem. There is more to that than just a carb.......just sayin'...
Chevyman1987
Tn
How much compression does it have. I had 110cc and seemed like it had good compression by just turning over found out later it didn't have enough compression. Might wanna put a gauge on it. And as poboy said above shoot some cleaner in it and if it don't fart then compression
gjordon59
Thanks for the replies, I'm going to set the valves today and see how that goes.
gjordon59
I've set the valves and it made no difference. I'm going to get a compression tester today and check that. It has what I thought was decent compression but from what I am seeing is that too low it won't start as well.
What would be the range of compression dry/wet that I am looking for?
Chevyman1987
Tn
Mine had right at 150.. Now I have done this on a motor just to test to make sure it ran before spending money on it. I would pour like 1 cap full of oil in the cylinder. Remove the spark plug make sure the piston is about half way up and pour in wait about 2 mins then turn over the oil will help seal the rings better on the wall and will let it run for a min if the wall is not bad. So if it runs that way it's most likely your gonna need a new top end but they are not too high I think I spent right at 60 for a new top end on mine.
gjordon59
Well I think the mystery has been solved, the dry compression was 35 at best so that pretty much sums it up. Just have to decide now to put a top end on it or go with an engine. The kart itself doesnt look to be that old. The guy I got it from said it was a 2016, but also said it just needed a little carb work. lol
Chevyman1987
Tn
If it's a nice kart it's worth putting a little money in the motor. It's not that big of a job on them motors and if you have never worked on one check out YouTube there is some great video on how to rebuild the top end. Hope it works out for you
