B&S Carb Question
Scotfree1993
Long Island, NY
Picked up an old B&S 5 HP motor. (FREE) Carb is missing.
Model # 130232 Tyoe: 3029-01
Found a replacement online for $90. That's crazy. I would like to rebuild the motor for a go kart. Could I put another carburetor on it?
As long as it's a comprible size to the original. You might have to get creative for the mounting and air filter.
New engines are going for just a few more dollars than that carb.
Staff Murderator
You can find old B&S carburetor "hulks" on fleabay all day long for cheap. You could get creative and look for a few in your local lawnmower repair shop as well. Then rebuild them for a few bucks.
Otherwise, there are aftermarket or other alternatives: Tillotson, Mikuni..basically any carb would work as long as you have the proper interface to attach it to the engine.
Check out Kentucky Boy's threads--he's done a few on the subject:
http://www.diygokarts.com/vb/showthread.php?t=33377
But it's actually pretty hard to beat a factory Briggs Flo-Jet or Pulsa-Jet carburetor.
Joe-405
Enjoying New Projects
U.S.A.
Those carbs are junk. When they work they're awesome but if they fail your screwed !
I work in a small engine repair shop and those are the worst to fix.
I would find a different alternative to anything without a gas tank attached to it !
