Piston and rod combo question
Bobby24
Oklahoma city
Im looking to get a billet rod and want a flat top piston for my non hemi predator
This rod that is .020 longer
https://www.ombwarehouse.com/HF-Predator-_020-3_328-Billet-Rod.html
With the hemi flat top piston that is .020 shorter compression height
https://www.ombwarehouse.com/Std-Bore-Hemi-Predator-Flat-Top-Piston-Kit.html
Will this combo work fine in my non hemi block?
Also I have a gx160 head to go on it and was wondering if anyone has an idea of what the compression ratio it will be with this combo.
My other mods are mod2 cam, billet flywheel, 26# valve springs, ported and polished head, with all these mods what about how much power would it have
I don't see why those parts won't work although, you may want to double check they are for the non hemi...
Figuring out compression ration based on a vague description isn't that easy, we need exact measurements of the bore, stroke, head gasket thickness & head combustion chamber volume...
Estimating hp is even more difficult; you may have all the internal goodies but, with inadequate carb & exhaust, you may only make 7hp; the only way to truly measure hp is to bolt the engine to a dyno; theoretical hp is just that, theoretical...
Bobby24
Oklahoma city
Guessing 11.4 : 1 CR
Don't for get the 8 degree offset key
And the octane booster.
My flywheel is already 8 degree advanced from arc.
If it is that high should i run the octane booster you mentioned or high octane fuel?
---------- Post added at 07:43 AM ---------- Previous post was at 07:37 AM ----------
I forgot to mention my carb is 22mm mikuni and exhaust is the one in this kit i cut out the baffle in the muffler
https://www.ombwarehouse.com/Predator-212cc-Go-Kart-Kit-Stage-1-Non-Hemi.html
Also im using stock metal headgasket
My engine is about 11.1 : 1.
You could be 11:5 or more.
I run 100 octane to be safe.
I could probably run 93.
You need at least 93, probably 100.
At least from what researching this topic says.
---------- Post added at 11:30 AM ---------- Previous post was at 11:27 AM ----------
Need some things to get more accurate.
Is stock gasket 0.010"
How far down in the cylinder does the piston sit at top dead center.
Should be like 0.020" to 0.040".
Also what is the volume of the dish in the stock piston.
Without measuring stuff and making some assumptions, 11:5 : 1 CR is a good guess.
I'd run 100 octane, but others may have a different suggestion.
Also try the AR3910X spark plug.
I ended up using the AR3911 plug.
Bobby24
Oklahoma city
I am using the ar3910x plug
I havnt bought the piston and rod yet, trying to get opinions first
Its the .010 metal gasket
I dont know the volume of the dished piston, and i dont know where top of piston was, my rod shattered lol
Well if there was no pop out before, then a +0.020" Rod and a -0.020" Piston should be fine.
I think stock CR is 8.5:1?
Bore = 70mm
Stroke = 55mm
Gasket Bore = 70mm
Gasket Thickness = 0.010"
Deck Height = ??? 0.025" ???
Dish Volume = ??? -3ccc ???
Chamber Volume = 22cc
8.45 : 1 CR
Seems Reasonable to me for stock.
Gx160 head is 14cc.
Flat top piston with longer rod and flat top shorter piston should make more compression too.
Not sure how much. (Sits same height without the dish)
Measure everything when assembling and pick a gasket after to get the desired CR.
This is what I use.
http://www.csgnetwork.com/compcalc.html
Depends on actual measurements on YOUR engine, AND choice of gasket, this should give you
a range of 11.4 to 13.5 CR
Bobby24
Oklahoma city
Bore = 70mm
Stroke = 55mm
Gasket Bore = 70mm
8.45 : 1 CR
Gx160 head is 14cc.
This is what I use.
Sweet thanks, i really appreciate it
