Chain size dilemma , what to do?
Triple a arsenal
On my new carter kart, I had to shorten the chain some, but I realized I prob need a half link. Of course for the RLV extreme performance chain they don't make them.
So, if I adjust the jackshaft, the driven pulley will move affecting the belt for the 40 series.
So what to do now?
Joe-405
Enjoying New Projects
U.S.A.
Just put spacers on the axle mounting blocks to take up the slack of the chain.
ML-TOYS
long island, new york
It looks like your jackshaft is adjustable and more than likely your motorplate is slotted too.
Adjust chain to jackshaft then move motor and keep the correct distance between the clutches.
Triple a arsenal
Yes jackshaft is adjustable, which was my first reaction but then I thought about belt.
Doesn't look like much room left to slide the jackshaft over in the direction I need to take out the chain slack. Do you have an option #2?
Triple a arsenal
Ok so I was able to make a chain with no master link, loosen the jack shaft and slide it forward. Slip the chain on and slide it back.
I marked the jackshaft before touching it, and comparing where it was to where it is now, a 1/4" forward. So the TC belt is now 1/4" too big.
I looked at the motor and there is room to move forward now, so I'll try a 1/4" forward tomorro.
I'm still not sure about the chain tension, the top tension is different than bottom tension. What's the proper tension and how do I measure it?
Triple a arsenal
Here is another problem, the 10t #35 is so small and the 3/4" jackshaft is so big the washer that holds the sprocket against the shaft touches the chain.
It's not in the picture because you can't see the problem then. The bolt holds a washer which should press the sprocket and jackshaft to hold it down.
well, add a bit more shaft to that side, cut a spacer from some tubing (to clear the chain) and then add washer and bolt.
10T #35 is hard on the chain the radius is just tiny.... only THREE links (four pins) in your setup in contact with the sprocket.. that's where ALL the load is going...
I'm not saying it won't work.. but I think you'll need to watch that regularly ;)
See, that's why you set the chain first :lolgoku:
You have a few choices:
- if possible, adjust the J/S to tighten the chain, then move the engine to adjust the belt
- move the J/S to tighten the chain, buy a new belt
- add a chain tensioner
- live with a loose belt (not advised)
Triple a arsenal
It's because I'm using an 80t sprocket, it's big so it doesn't allow any more chain on the 10t.
Joe-405
U.S.A.
Or I bet you can put a lock washer then the regular washer on. They are usually small enough to clear stuff like that.
Triple a arsenal
I see that now lol, I am trying your option 1, I'm half way through it.
I need to move the motor tomorro.
The belt number according to gokartsupply should have been 8-3/16" from center to center drive/driven. And before I touched it I measured to make sure and it was dead nuts, 8-3/16".
I'll just make sure to move the motor up 1/4" and I should get the same
8-3/16" center to center.
---------- Post added at 10:20 PM ---------- Previous post was at 10:17 PM ----------
I'm confused, the nut and washer screw into the jackshaft to do what?
I though it was to have the washer block the sprocket from coming off the shaft? If i use a spacer to extend it or a small lock washer first, am I defeating the purpose of the bolt? Because then it would not stop the sprocket from moving....or am I totally wrong?
You use the spacer and the washer. The spacer sits on the shaft and hangs over a little, so the washer still pushes the spacer against the sprocket but clears the chain.
