Well crap I wonder if I did it on the minibike. But that wont limit rpm just speed tho correct ?
And do you have a video of winding it. I should still check it.
Correct.. overly tightened the spring will prevent the driven from opening up all the way (your current top speed tells me it's not the case though)
but it'll also delay upshifting (internally) sooo you also lose a bit acceleration
Best video I've seen is the maintenance video made by Grant
www.youtube.com/watch?v=a3FCcLlR-sg
the last minute shows the preloading step.. but it's easy basically.. choose your hole, and preload exactly one valley.
That's confusing Sid.
That pic you posted shows one at say 0° the next is at 90° and the third is 180°.
Is that how the line up with the cams?
I thought they would be more of 0° 45° and 90° or something like that.
This is more of what I was thinking....
http://www.diygokarts.com/vb/attachment.php?attachmentid=75926&d=1473647669
No in regards of the one hole you have it is
-90° , 0° (the one you have) and +90°
the cam lobes are 120° apart and it's important to keep the reference.
And yes, the holes on a series 30 are much closer together..
but we talk series 40..
So I just noticed mine has the 3 holes. But only the middle is drilled out all the way.............
Might check yours. And here's a good pic.
that's indeed the view I was hoping to find online earlier.. thanks for posting it!
WTR, if you take a close look you can see that those cast flash circles
are a good point of reference as to where you need to drill.
(and you can clearly see your's is between two such flash circles just as the 'std' second hole on the predrilled one)
