Changing Flyweights in comet 40
Hi.
I have recently acquired 2 Manco Dingos each with a 9hp B&S OHV.
They have a comet 40 series torque converter. I see there are different springs available to adjust the rpm engagement.
No where have I found the pull strength of either the red or yellow springs.
Also I have never seen other fly weights for sale.
Maybe in not looking in the right spots....
I have access to barstock and a lathe and can make my own fly weight at any weight I want.
How much weight difference does it take to effect the clutch?
Make sure to NOT mistake the pull springs in the driver with the tension spring of the driven
(both come in red or yellow.. but do very different things)
Weights are only available in heavy (the std weights) medium and light.. whatever that means in terms of weight...
order numbers are
203648A for a set of three std "heavy" weights,
203649A for the "medium" set of three and finally
203650A for the "light" set of three...
springs
203040 "red" pull springs (again set of three)
engagement speeds: heavy: 2000 rpm, medium: 2600 rpm, light: 3100 rpm
203043A "yellow" (standard) pull springs (also 3 of course)
engagement speeds: heavy: 1600 rpm, medium: 2200 rpm, light: 2400 rpm.
That's all I found too Sid.
Heavy medium and light.
Is there more info as to gram weight of each or a pound pull for each of the springs?
I clocked my dingo at 40mph top end with 18 inch tires. The other has 22" rubbers,Still in the shop.
9 tooth on the JS and 54 axle.
I'm always tweaking things and would like to personalize the clutches.
Ummm in my driven the yellow is for reverse wound setup.
Well Joe... read :D
Nope, no more info..
buy them and test?!
frankly.. all they do is to change the engagement speed of the clutch..
they will have absolutely no effect on top speed or anything BUT said engagement speed,
as long as the TC is not engaged at idle, and able to fully "shift" up.
If that's the case, there is absolutely no need to tweak.
beltpalace.com carries all those weights and springs.
Looks like 204524A is the reverse yellow wound DRIVEN Spring Joe Mentioned (for mounting the Driven the opposite direction, right?).
Sid shared 203043A 40 Series Torque Converter DRIVE Unit
Comet Spring Yellow Standard.
Well Joe... read :D
Looks like 204524A is the reverse yellow wound (for mounting the Driven the opposite direction, right?).
Sid shared 203043A (standard wound).
really.. :toetap05:
ARE YOU EVEN READING the posts at all??
WE DO NOT TALK ABOUT DRIVEN SPRINGS​
OP made that very clear with his post,
I made a warning in the very first sentence in my reply..
First Joe, and now You ?!!??!!!??!!!
And no, I did NOT post a std wound driven spring... check the numbers!
Yes, it was a bad move from comet to color both the driver and driven springs in red and yellow.. I admit that much..
but if you pay attention it's not too hard, is it?
:smiley_omg:
It seems like the topic went over some heads.
I was asking about the driver unit. The one attached to the engine crank shaft.
Sid has been helpful and posting part numbers and websites. This helps for future readers looking for the same info.
How about some one who has a comet 40 series and a scale, and perhaps someone who has bought the other size weights chime in and help.
Or some one who has a fish scale and the red springs.
There has to be some info out there.
:cheers2:
kevbo22
Colorado
I have the red springs and the medium rollers.
I can weigh the heavy and medium rollers tomorrow and post.
They dont sell the light rollers anywhere!!!
As far as the springs "pull strength", I cant help you.
really.. :toetap05:
You are correct Sir. My deepest apologies.
I shall edit my post so that it looks like your large red letters came out of anger for no reason. People will have to read the quote and I will claim that you changed my words to make me look bad. LOL
Sorry.:cheers2:
If you read what you quoted CAREFULLY...
Is it misleading? Yes.
Is it technically incorrect? No.
JK, your knowledge is extremely helpful and I truly do appreciate all the assistance you offer.
Thanks for allowing me to soak some of it up and thanks for putting up with my terrible sense of humor.
kevbo22
Colorado
Kevbo. That would be great.
Do you have the other springs? Or not know how to measure them?
I have the red and yellow springs. I dont know how to measure, or if I even have the tool you would use to measure them. Exactly what did you have in mind to figure the "spring pull strength"?
If you read what you quoted CAREFULLY ...
Thanks to you editing the post after I replied.. it's not nearly as misleading as it was when I quoted ...
now it's just pointless :D
And yes it was -thanks to the context- incorrect,
but let's just forget about that..
the red text -just so that you know-
was meant to keep the third misled member from posting another comment about the driven springs :D
Check beltpalace I've just seen 'em there ;)
if you got a luggage scale, that'd be perfect...
fix the spring somewhere, attach the other end to the scale and pull until the spring STARTS to stretch;
read again after the spring stretched about 1/4".
(do not overstretch the spring!)
ideally you'd want the max value too.. but that's close to the point of no return and thus should be left alone in order to keep the springs alive ;)
horizontal btw.. but doesn't matter much for this task :D
Kevbo. Do you have a fish scale. The thing you hold up and the fish hang on the hook.
Take one end of the spring and anchor it. Then pull gently till the spring just breaks, read how much pull this takes.
Pretty easy.
You can measure "push" springs by putting them on a bath scale and use a press. Same concept.
We measure valve springs like that. Easy to spot a weak spring.
Sid's a fast poster.
kevbo22
Colorado
I'll check beltpalace!! :thumbsup:
I wont be stretching my springs for the sake of curiosity.
I will still weight the cam rollers because Ive been asked this question before with no answer.
Honestly Whitetrashrocker , all the info you need on engagement sid said and here is the 40 series engagement chart.
I may change my mind about the spings tomorrow, but doubt it as I have no luggage scale and my fish scale is in an unknown place right now.
Thanks again kevbo.
I have not seen that chart but it's the same info that Sid posted.
It looks like the spring pull is on the chart.
Yellow is 14# or 14lb pull
Red is 28# or 28lb pull.
Now to put the weight of the Flyweights...
Thanks guys!
kevbo22
Colorado
The heavy rollers (203648) are 130 grams
The medium rollers (203649) are 96 grams
Like I said before, I dont know what the light rollers are because I dont have a set and I cant find any for sale anywhere (including beltpalace).
I would like to get my hands on a set "just to have".
I weighed mine also.
I got 96 grams each. Give it take .9 grams.
So the three give a total of 288 grams.
The heavy set totals 390 grams.
For a difference of 102 grams.
That's the info I was looking for. How much difference between the sizes.
I was buzzing around the yard track and either I want lighter springs or I'm gonna make some heavier weights.
This 9hp has enough power to pull and want the clutch to engage at a lower rpm.
