Disabling Governor VS. Removing Governor
ironbutt
Pacific Northwest
No this is not about "The Walking Dead".
I've got a Predator 212cc on a Motovox MBX10.
According to my cellphone GPS speedo app I'm not going above 28mph with the stock configuration (which feels pretty fast btw).
I'm not excited about pulling and opening up the engine to remove the complete governor apparatus. As well, I like the idea of still having the governor available in the future in case I swap or repurpose this motor later.
I was considering just disconnecting the throttle linkages to the governor arm and locking it back somehow if necessary (or could it swing freely?).
But I looked through previous threads here and saw a similar discussion from 2014 in which member Itsid was adamant against that approach...
:Quote
there is such screw..
and I will not tell you where it is
Main reason: you shouldn't!
What you describe as the throttle limiter is in fact a governor,
and it does more than just limit your throttle.
It is a small plastic gear INSIDE the engine that will break if only bypassed.
So in order to disable it, you will have to remove it for the safety of your engine.
look up "governor removal" and you'll see
:End Quote
Is it actually dangerous to leave the governor gear and actuator arm in the engine? It seems like it would just be in the same state as when it is running in lower RPMs.
If I do just disconnect the linkages (and even remove the governor lever) does the arm bolt need to be secured in a certain direction or can it swing freely?
Thanks in advance for your input!
:cheers2:
Here is what it looks like, disassembled.......
There is 2 "weighted"(none the less actuated by centrifugal force) arms and a plunger to depress the arm to retard the carb when at the desired speed.
No retardation, it will exceed the desired amount of limited speed and then eventually disintegrate into pieces. Those metal levers are a big problem to the gears on the crank and cam.... should an occasion arise the happen to get a "wrench in the works".
ultralight01
Senior Yet Young Member
Hood River, OR, In a galaxy far far away
I do not know if the gear is spinning the entire time or if it is only engaged when the throttle is at max, but it's always best to just get rid of it. While I'm not gonna say it's fine to leave it bypassed, I don't know of anyone who has had a governor gear blow up on them with mods. I have friends who bypassed them and raced 60 laps.
In short, if you want to risk a $100 engine, go ahead. But it may save you plenty of frustration to just take a couple bolts out, remove the side cover, and pull out the gear! It's simple!
Where have you been?Look through BbqJoe's posts.
And yes...it's spinning ALL the time.
---------- Post added at 01:03 PM ---------- Previous post was at 12:50 PM ----------
This is only one method for fixing this problem, but it worked for me.
First remove pull starter assembly, and check for proper operation, might as well clean it while you have it out.
If you have broken your rope due to having to pull too hard, now would be a good time to replace that too!
If the pull mechanism is working, proceed to the next step.
Remove spark plug, and try to pull rope. If rope pulls easily, follow next procedures.
1. Remove exhaust.
2. Remove carburetor. Plug fuel line or drain tank.
3. Remove plug wire and plug(you've probably already done this, if
you put it back, pull it out again.)
4. Remove fuel tank.
5. Remove chain.
6. Remove drive assembly. (Jack plate, clutch, torque converter etc.)
7. Pull fly wheel.
8. Drain oil. (Do not discard in sink or sewer system. It is easiest to
put drained oil back into an empty container, and place on the
neighbors front porch while they are away.)
9. Remove mounting bolts from engine.
10. Carefully lift engine from mounting plate.
11. Place engine on work bench.
12. Remove side plate bolts.
13. Carefully remove side plate. (if you kill the gasket, stop right now
and order a new one.)
14. Carefully remove camshaft. (This is where your compression
release mechanism is located.) See pic #1. Yours may look
different, but most are located on the backside of the cam gear.
PIC #1
15. Obtain tweezers and small forceps, or small needle nosed pliars.
16. Remove all governor bits and pieces jamming up decompression
release. Now is also a good time to look for and remove all plastic
pieces and metal bits from crankcase and bearings. Bits should
resemble those in pic #2
PIC#2
17. Once you are certain that debris has been removed, look at the
other side of the engine. Locate governor shaft protrusion.
(Shown pic #3.)
PIC#3
18. Using a small punch or drift, carefully knock the governor shaft
and governor back through crankcase like you should have done
in the first place* when you disconnected the governor arm on
top of engine.
19. Plug hole, or re-seat the governor shaft only back into hole.
20. Mount, and reassemble engine. Don't forget to add new oil!
21. Engine is easy to pull start now. If not, buy preditor 212, and try again!
*Please note, Chancer is a really good guy, but sometimes gives really crappy advice ;).
See above..
Bbqjoe
Banned
Location, Location
Mr IronKeister, I thought just like you are thinking.
Really, once you get started, it's a piece of cake to remove it. My dog could probably do it.
It's not like you're opening up a jet engine. There's relatively very few parts in there.
Have a Mountain Dew, and just Dew it!!!
ironbutt
Pacific Northwest
I'm not worried about doing the actual work, it's just that I'm in an apartment and don't feel like taking engine out of the bike and working on it in the dining room.
I was hoping for a more field expedient option.
I get the message though. Leave the governor in place or completely remove it.
I figured as much that's why made the
OP.
Thanks!
I don't know about that. I don't have a garage and I work on small engines outside all the time.
I even did a complete rebuild on the 2.0 Split Port SOHC engine in my 2002 Escort in my driveway. It's been running strong for 3 years now.
I see you have already gotten the point but I must redeem myself from last months poor advice.
DO NOT BYPASS THE GOVERNOR LINKAGE. REMOVE IT COMPLETELY!!!
If nothing else the plastic teeth when shattered will get into your cam's compression release spring and make the motor hard to start. This happened to me, and I did not even know (scrapped a motor) and Happened to BBQJOE last week, when I realized that was my problem.
Worst case is what McKutzy said, metal parts in the crank and cam. OUCH.
There is that the correct advice guys. :)
And frankly.. what happend to Joe was more in the realms of LUCK than bad luck.
one of those metal parts could've endded up at the cylinder wall and lock the piston on a downstroke..
THAT would've been a disaster.
a plastic part locking the compression release is compared to that just a minor issue.
So yeah.. as said above:
removal or left alone are the only two options for your governor.
