A quick question
thebroketeenager
Bakersfield California
Hey guys I have 2 clapped out old GX160s laying in my sideyard. I was wondering id anybody knew if a GX160 head could bolt onto a 212 predator without milling the piston or anything like that. I'm looking to add more torque with more compression and a port and polish job on the smaller GX160 ports. Thanks!:thumbsup:
^ agree.
Should fit fine. Keep 0.030" clearance between head and piston top at TDC.
Dowel pins aren't really needed. They just hold the gasket in place, right?
thebroketeenager
Thanks for the responses! I'm not sure about not needing dowel pins bob. They are used for aligning the gasket but I believe the head as well. Even with the bolts torqued(212 doesnt use studs) the head I think could be misaligned. I'll probably try it anyway hehe. Thanks again!
Sent from my KFOT using Tapatalk
thebroketeenager
Ok, so both motors are disassembled. The head on the hunder was pretty crusty. On the other hand, the head on the predator looks pretty good aside from some carbon buildup. The bore on the predator looks great as well, which honestly surprises me. I've ripped on that thing for hours in the dust with pretty much no filter. But anyway, I cleaned up both valves on the honda and they came out well. The seats are ok, but the valves are pitted so I'll have to lapp them.
Bwdeaton is correct, the bores of the motors are the same but the dowel size is different. Im not sure how I'll align the head correctly.
Right now I'm waiting on my dad to get home so I can use the lapping tools he may or may not have. I'll have to ask one of my friends if I could use his dremel to clean, port and polish the hundur head though, so dont expect great progress until maybe tuesday.
Staff Murderator
If you're really adventurous, you could find an automotive machine shop nearby to grind new faces on your valves. The exhaust valves always seem to look crusty and usually have some pitting but it's nothing that a valve grinder/re-facer cannot handle.
I had two Briggs valves done recently. They look like new and it was cheaper than just replacing them. This is just one part of the old school "valve job" procedure...
thebroketeenager
I would if I had the money and means of transportation, but without a liscence or a job I'm kinda screwed.
UPDATE: Turns out my brother has a dremel. The job I did I would describe as mild, just got rid of rough edges and did some minor polishing. Pics tomorrow.
Staff Murderator
The other option is just to hand-lap them in anyway, first with the coarse compound and then the fine. That's what I was going to do on my Briggs flatty.
I don't know what bit or tool you used on the Dremel but if it was in any way like a grinding wheel that may have altered the valve faces (or their angles in comparison with the valve seats), lapping will help restore the proper profiles.
thebroketeenager
Yeah, since im a huge hack, i'll probably end up using toothpaste for lapping compound. I used a steel wire brush on the the outside of the valves, and a brass one for the more delicate areas.
20 Years!!! You are either really dumb,
or some kind of Doctor... Proctologist???
OK 19 years.
Pre K
K
1-8
9-12
5 years in college (12 hrs per semester).
https://www.youtube.com/watch?v=1XHcPYorSJw
---------- Post added at 05:43 AM ---------- Previous post was at 05:38 AM ----------
I'm gonna need to for sure. I have college level classes this year as a sophmore in high school. :surrender:
I'm at home now. Got home later than expected, my moms car died.:2guns: Will likely upload pics later tonight or tomorrrow morning.
I am glad I took AP calc in HS. I had no clue what was going on in that class.
BUT first year in college I got an A in my 5hr Calc 1 class.:thumbsup:
