Predator 212 hemi
ericb
So I have a gokart with slicks with stock Predator 212 Hemi and now I want to change the tires and put off road tires I also want to build the engine my plans are taking off the governor which I believe I would need to change the flywheel and rod. Also change valve springs I don't know about a cam nor jetting the carb or just changing the carb? Any suggestions on a nice setup to have more torque and Power when I hit the pedal. I want to feel the difference in the mods I've also heard about changing the timing I'm new at this so please help me out and any suggestions would help I want to know if I can do this with $300 or less
I would just suggest doing the changes one step at a time. So you can see the improvements as you go.
Removing the governor will just allow you more RPMs increasing top speed, but not "more torque and Power when you hit the pedal."
Bob58o will chime in here real soon and get some good advice.
Here is the best advise I can think of, for a change you can really feel bolt in a 420 and be done with it. It will cost you less and have better reliability in the long run. :thumbsup:
How Quickly $300 goes.....
DON'T CHANGE VALVE SPRINGS UNLESS YOU GET A BILLET ROD.
If you already have a Torque Converter, then skip #2.
1. Governor removal
$FREE
I like this method of removal. If you do #3 on this list, then you will be taking the Flywheel off anyway to install the key that advances the ignition.
Need a punch, 1/4-20 tap, 1/4- bolt, and some loctite.
https://www.youtube.com/watch?v=d6tUssrcK1I
This guy is good. Good luck.
https://www.youtube.com/watch?v=LJK3HgOs1Gs
Standard brute force method (usually just break the plastic gear off)
https://www.youtube.com/watch?v=61zQaE_8tIM
2. 30 Series Torque Converter (if you have a centrifugal clutch currently)
$73
http://www.ebay.com/itm/3-4-CLUTCH-...526478?hash=item3d0813e48e:g:rG8AAOSwWZ9XoVac
Adds Torque, Adds overdrive, Auto Transmission, Better take off, Better Climbing
Install video
https://www.youtube.com/watch?v=ToWVQCO2Lg8
3. Stage 1 Hop up Kit from OMB
$76+shipping
Includes
Air Filter Adapter
Air Filter
(includes Choke bracket, long carb stud, gasket)
0.036" Main Jet for Stock Carb
0.037" Main Jet for Stock Carb (gives you two options)
gx140 Emulsion Tube
8 degree advanced timing key
Weenie pipe exhaust
Screw on muffler
https://www.ombwarehouse.com/Predator-212cc-Go-Kart-Kit-Stage-1-Hemi.html
Install video
https://www.youtube.com/watch?v=K8eBsBrWwYw
Engine (sounds meaner w/o the screw in muffler
https://www.youtube.com/watch?v=zKH4C-WC890
Karting around
https://www.youtube.com/watch?v=Z9avWSo2WWE
4. Billet Rod (stock length or +0.020")
Needs 1/4 12pt (if I remember correctly) socket and torque wrench
Standard 3.308" ARC 6254
$84+shipping
http://www.arcracing.com/6254-arc-billet-rod-hf-predator-212cc-3-308-std/
Or for more compression (if your deck height allows)
Long +0.020" 3.328" ARC 6256
$84+shipping
http://www.arcracing.com/6256-billet-rod-hf-predator-020-3-328/
Install vids
from ARC
https://www.youtube.com/watch?v=owahpOeLYaw
and from our very own KartFab
https://www.youtube.com/watch?v=h11vVn5f_3s
5. Valve Springs
18lb for hemi with stock cam and rockers
$8+shipping
http://www.nrracing.com/product-p/dcs-an2.htm
install video
https://www.youtube.com/watch?v=4QZWV6S-5aA
6. Hemi Gasket Kit
$10+Shipping
http://www.nrracing.com/product-p/gasketkit-65-hemi.htm
Includes a 0.010" Head Gasket which is too thin if you use the long +0.020" Rod
If you get the long Rod add one of these too (the 0.010" will be too thin)
7. 0.027" Head Gasket
$15+Shipping
http://www.arcracing.com/dj-1310p-27-predator-head-gasket-027-70mm/
or 0.036" Head Gasket
$15 + Shipping
http://www.arcracing.com/dj-1310p-36-predator-head-gasket-036-70mm/
AND NOW YOU ARE OUT OF THE $300 YOU STARTED WITH.
IF YOU ALREADY HAVE A TORQUE CONVERTER, THEN SPEND THAT MONEY ON #8 - #9
8. Cam Shaft
$50+shipping
http://www.dynocams.com/item/cl-cs/hemi-mod/
9 Carb
Bored Race Ready? Just an option.
$50+Shipping
http://www.arcracing.com/dj-2225-race-ready-cnc-bored-615-box-stock-carb/
Lots carb options, but the stock might work OK.
JUST A BIT OVER BUDGET, CHANCER WE NEED CHEAP TIRES.
ericb
What is a 420? Is that a engine size?
