Go kart project twin engine 18hp 21ft/lbs Duromax
Jackseale777
Sweet Home Alabama
Update: have both motors broke in, had to customize the whole read swing arm to about 17" wider and 13" longer. So the rear swing arm is now 48" instead of 25-27", colors are gonna be flat black and blue. I'm almost done painting, I'll order the two 40s this week or next. Should look pretty cool and definitely gonna be fast!! Bout $1200 more before I'm done estimating.
Jackseale777
Sweet Home Alabama
Started on the rear wing arm, hopefully I can finish it tomorrow and maybe test fit the motors. Also, painted the main frame today! Looks good flat black, control arms & wheels are gloss blue with a gloss Clearcoat. The flat black has a flat clear coat on it too. I'm having trouble in my head trying to figure out how to setup the two throttle cables situation.
Planning on 1:5 setup and a 1:6 setup. What would y'all suggest?
Well do you want to wheelie over backwards or do 100 MPH? LOL
What size Tires?
Forgive me if the info has been posted.
5:1 or 6:1 is what people use with a single 5-8HP engine and a CC.
You have a beast and could probably get away with 2:1 or 3:1.
It depends on tire size and desired top speed / torque.
MrC.
florida
Looks good from what i can see
I bet alot more than 400lbs.
Keep digging you will get there.
MrC.
Jackseale777
Sweet Home Alabama
definitely around the 400 range. The frame in the pic probably weighs 120-130, the rear end will weigh around 100-120 with the axles,sprockets, mounting plates and brackets, and each engine weighs 77lbs. , plus the seats and battery is gonna be 60-80 probably. So thats 434 now. So id definitely say about 450-500lbs. but thats what a mid sized streetbike weighs so it still shouldnt be too much especially with most of the weight being over the rear tires. I'm happy so far with it!
