I'd like a larger tank for my clone.
Bbqjoe
Banned
Location, Location
Does anyone make one?
.85 gal just isn't that much gas. I've looked around and haven't seen a clone or honda replacement that is larger.
DeathMachine
Eastpointe MI
Beer keg....
You can mount a racing style tank or pretty much any kind of tank on the frame, just has to be higher than the carb for gravity feed
Can you convert the "dummy tank" to an actual tank?
Then add in a T and a couple shut off switches and have both.
Bbqjoe
Banned
Location, Location
Beer keg....
Well obviously. And I can balance a 5 gallon bucket on my head too.
But that's not what I'm asking, is it?:roflol:
---------- Post added at 07:56 PM ---------- Previous post was at 07:54 PM ----------
The thought crossed my mind, but I like having the glove compartment.
Meh. Glove compartment Pffft!
You got that big basket on the back add a metal ammo can.
Knowing you there are several EMPTY ammo cans at Fort Joe!
Bbqjoe
Banned
Location, Location
Fill an ammo can with fuel???
I COULD carry around an extra fuel can, but then where would I put my ICBM, and my puppy?
DeathMachine
Eastpointe MI
There's no larger Honda GX clone tanks available because there is no OEM need for one. Generators are pretty much the only thing that need extended run time, and those are made by the generator manufacturer. They hold 5 gallons, but are HUGE and don't really lend themselves to a minibike.
You can get small 1.5 to 3 gallon motorcycle tanks, Sportster style or Brit 'peanut' style tanks, they are a couple hundred dollars new but there's usually lots of them at swap meets for around $50.
Joe-405
Enjoying New Projects
U.S.A.
I have a new powerland 420cc tank that I pulled off cause it wouldn't clear my frame. Never had fuel in it if it's bigger.
No use the ammo can for a glove box and the fuel tank for fuel!
Get a shoulder Holster for the ICBM
Well is the 420 tank bigger than .85 gal? It should say in your Owners manual. (as if you kept that) lol
DeathMachine
Eastpointe MI
Just tow one of these behind you
Bbqjoe
Banned
Location, Location
I have something almost the same. I was also thinking about rigging up a line so my wife could drive next to me in the car, and fuel me up as I ride. :)
The youtubes aren't working for me on this site today.:censored:
I'm looking to do the same thing with my Motovox, but I can't find any cheap gas tanks larger than 2.5 ltr.
Check out:
http://www.gasbike.net/collections/gas-tanks/products/oil-and-gas-tank-2-5-liter-2-5l-black
It would look good on a mini but has less capacity than my Predator fuel can.
Seriously, what can you do with 2 1/2 liters? Not much. I'd like at least a gallon or a gallon and a half.
Joe-405
U.S.A.
Actually wise guy I did............ 6.5 liters which equals 1.717 gallons so the manual says............
That is wise! No offense, I just figured you being a Racer were the type to toss that before getting the engine out of the box.
And that tank would be double his current capacity. Sounds like a good plan.
