Another Blown Predator 212
Grape Ape
Virginia
I don't think I want to pull on one that is 18.7:1, may pull my arm off. Can an engine with that type of compression ratio even run of standard gas? I think 87 is out of the question but I don't know.
DeathMachine
Eastpointe MI
If it is truly 18.7:1, they must be using valve timing to bleed of some cylinder pressure. That's in the range of diesel compression ratios.
And I still can't imagine pull starting that.
Blown 212 with a Smog pump. That would be PAFR.
But I did see something interesting today from GAB.
A stock Tecumseh uses forced air direct from the Cooling fan. The stock air cleaner has a hole that attaches right to the Fan Shroud.
Interesting.
I saw that too..... maybe ill have to take a hose and put it into the hole in the clone shroud(where they stock kill/of switch is), pipe it to the airbox....
HMMMMMMM...... man that brings me back.... Im sure we talked about that MANY years ago, "self-supered" motor......
Lots of things to consider including Spark Plug Heat, Camshaft Timing, Air Fuel Mixture, Ignition Timing,.....
BUT NO, You cannot run 87, 89, or 91.
You cannot run 93, 95, or 97.
You cannot run 100.
This engine did not have 18:1 CR.
Where would the valves go? Right Through the piston?
Grape Ape
Virginia
So everyone is of the conclusion that the chart is wrong, I did not think it was anywhere close it just did not sound right. So now the question is what is the compression ratio for what I got. Time to break out the instruments and find out or unless someone already has done so.
I don't think somebody would mill a 14cc head another 0.050"????????
I'd CC the chamber if I was you.
Squeezing 212cc into 11cc is like 18:1.
Squeezing 212cc into 18cc is like 11:1
The most I've heard is like 212 into a 14cc Chamber for a 15-16:CR and this probably needs 110 octane.
DeathMachine
Eastpointe MI
An internet classic....
Grape Ape
Virginia
Thanks DeathMachine for the DEI post but it does not help the discussion (it is a internet classic) but 11cc heads for the Predator are available and people are using them (I may use it but not with the existing compression ratio), I may be using the thickest head gasket I can find it all depends what it takes to make engine run on regular high test gas. I do know now that carburetor work is going to need to be done also.
DeathMachine
Eastpointe MI
Here's my thought on an 11cc head:
It obviously exists, you have one.
However, I don't think it's intended use is for a 0.00" deck, but for a dished piston.
18:1 is diesel territory, in other words- if you could get it started, the pre-ignition from compression would knock a hole in the piston before very long.
What you have, is a collection of parts from someone trying to build the 'ultimate 212cc' without any real understanding of how an engine works.
The 11 cc head is probably supposed to go on a gx160.
14:5 : 1 CR seems more reasonable????
I wonder what the piston to valve clearances are on a 212.
Why go for so much compression?
CFMs are KING.
CR is secondary.
Without some serious work, an 11 cc head won't flow as good as an 18cc head.
Also why try to rebuild an engine that just blew up the same way it was before.
---------- Post added at 01:08 PM ---------- Previous post was at 12:55 PM ----------
See!
Going from completely ignorant to "wannabe" engine builder takes no less than 75 pages on this forum!!!!!
Ask me how I know.:feedtroll::roflol:
:lolgoku:
Everything needs to be considered together - thought of as a whole.
Track Size or riding location (long vs short, stop and go or all WOT)
Tire size -
gearing -
powerband -
Clutch engagement -
CR -
Fuel Octane -
Camshaft Lift, Duration, Overlapp, Center Lines, LSA -
Carburetor -
Ignition Timing -
Spark Plug Heat -
Exhaust Pipe -
And everything else.
A stock cam's event timing may not work with that CR.
The P2V clearance may be too tight with a head shaved that much.
You will probably have to retard the timing with that much compression.
And then once the engine gets hot and pointy things in he chamber start igniting the compressed Air Fuel Mix before the spark happens - bad things will happen.
So you need a cold spark plug and a polished chamber.
Now that you've changed the timing and spark plug heat, the AFR will need to be adjusted.
It goes on......
Best of luck.
I'm no expert but researched a lot and have some experience with this kind of stuff. I won't link my thread, but you can ask me anything and if I can answer, I will.
Grape Ape
Virginia
Thanks for all the great information, could not get engine to run with the 0.01 head gasket and 97 octane fuel with octane boost (just what I thought) so this weekend I replace the head gasket with the standard head gasket I had (0.03). What a bear to pull but I got it started and it runs. Don't have kart ready yet to try it out but it runs great so far. I will see if I can post a video.
Grape Ape
Virginia
Thanks bob58o, I did not have one and wanted to see if I could get it running this weekend. I am ordering parts for the kart and will order one. for what I am doing don't need all that engine but does give me room to play (don't think I will ever need upgrades for this one). It was a good buy at $100
Grape Ape
Virginia
Help, got engine on the kart and did a couple of runs up the road and every time you hit the throttle the engine hesitates and then takes off. Thought it was a fuel issue so went back through the complete fuel system (gravity fed fuel tank), hose, carb (Holy Moses). Found some trash and thought I had it fixed. Put it back together and same thing. So then I decided to use a standard carb from a predator 212 that a friend gave me and the exact same thing. Spark plug is not wet but does have a little black around the outside edge. What is everyone thought, not enough fuel? I know that the original user had a fuel pump and remote fuel tank but did not want to go that direction if I didn't have to.
Grape Ape
Virginia
Will not run on choke, truth is it will not start if you choke it at all. Sounds like to much fuel but does not show that on the plug. Race Day and first showing of new kart Sunday and I can't figure this out. Frustrated!
Bbbwwwooooooggggggg!!!!!!!
Can you ease into the throttle?
Does it only happen if you whack it wide open from idle?
Not familiar with your carb, but seems like the idle jet may be too large?
---------- Post added at 12:12 PM ---------- Previous post was at 12:05 PM ----------
http://www.dirtbikeworld.net/forum/showthread.php?t=2463
1/ Bog/Hesitation off the bottom when throttle is cracked open.
*This is the most common compliant on the modern 4 stroke,
The hesitates ion is usually caused by the mixture being too lean in the 1/8 to ¼ throttle area.
Try the mixture screw at the front underside for the carbie. On most, Yamaha’s and SX model KTM’s it’s easy to get to, on electric start KTM’s it’s hard to access.
Remember that this screw controls the flow of fuel, not air into the motor side of the carb. This means clock wise is leaner and anti clock wise is richer.
Try turning the screw anticlockwise ¼ of a turn (from where it is set) and see if the bog is better or worst if you can’t tell, go out an other ¼ turn and try again.
This mixture screw has a fairly wide range of adjustment and effectiveness.
If the problem goes away by winding the screw out a ½ turn or so great! Your done, if you had to turn it out a full turn or more you had better check just where the screw wound up, buy counting the turns from the setting out now have to full closed (wound in) if it’s was more the 3and 1/2 turns out you can go up a pilot jet size and wind the mixture screw back to 2turns out. It’s worth checking, as if the screw is too far out it can loosen and drop right out and you don’t want that!
If the problem is worst or no better the more you wind the screw out, try ¼ in from your ordinal starting point. Again if the problem is gone with a 1/2 turn or less your work is done! If it takes more than that you can drop a pilot jet size and set the screw back around 2 turns out. This means your bike was running too rich.
Small changes in jetting like this, are usually required because of weather/altitude changes ,or because of modifications to the exhaust system.
On a machine that fails to respond to the adjustment of the mixture screw you should look for and eliminate the following.
Eliminate the fuel as a culprit. I always drain the fuel and use fresh clean fuel (the only fresh clean fuel you can rely on is RF100, AV gas, failing that, fuel from another bike that is running fine).
If fresh fuel didn’t help, you must strip the carb and clean the jets.
Water and dirt can block the pilot jet or mixture screw circuit. Also strip the accelerator pump as I have seen some stop working because of mud and dirt stopping the diaphragm from functioning. If the pump stops working the bog is always very bad.
Note; Dirty or over-oiled air filters can some times make life difficult for throttle response by cutting down the flow of air to the motor (this makes the bike run rich).
