Yup, Horstman HDC5B. Looks worn to me, I raced KT's for a bit.
Try this: Take the 5 spring compressors, and losen them at equal turns. The tighter the springs, the higher rpm is required to engage the clutch.
Basically, make it simple for the clutch to engage. If it engages more with looser springs, then your discs need replacing or you're on the right trail here.
