ironbutt
I'd like to add a swingarm to my Motovox 212cc Mini.
I'll probably get it made locally rather than buy one.
I know that for the chain tension to be steady and not jump off while using a swingarm, it's best to use a jack shaft close to swingarm and inline with the angle of the rear tire/sprocket.
Is it possible to use a jack shaft as the axle for a swingarm so that the travel arc is identical and also to reduce complexity and fabrication work?
Would I have to use wheel bearings in order to support the RPMs of the jack shaft and the weight of the rear wheel?
Any help, suggestions or wise tales of your experiences is greatly appreciated!
