Lifan 6.5 wide open throttle issue
Bnagy
Mont Belvieu, Texas
I got a like new Lifan 6.5 from a friend recently. When I removed the tank to clean it out I noticed the T bolt laying on the block, but I wasn't sure what it was. Long story short, got everything back together and fired it up and it stays wide open. There is no idle. Took the tank off and found that the T bolt holds the (governor arm?), with the springs on it, to the shaft. Fired it back up and it is still wide open no matter how I adjust it. Can someone school me on what needs to be done???
https://vimeo.com/177182028
Check to see if the throttle cable is pulling the throttle lever open a bit from when you had installed the cable...sometimes when you tighten the cable you may pull it slightly.. then you have it open always, causing a runaway....
It happen to me a time with a brand new engine...
In the pic it looks like the throttle rod from the gov arm is not attached to the carb.
Sorry the governed linkage is nothing I have experience with. I was going to say loosen the big nut in the middle, but it appears you are not using that lever with the gov.
---------- Post added at 08:38 AM ---------- Previous post was at 08:34 AM ----------
Isn't a Governor supposed to keep it running at 3600?
This has always confused me.
Does it work like cruise control?
How do karts with govs not drive away on their own if they run at 3600 RPM as soon as you fire them up?
What does the pedal do if the throttle plate is always open the amount needed to make the engine turn 3600 RPM?
Is it the return springs that overrides the governor and closes the throttle?
so the governor control arm (elbow shaped silver thingy) was not firmly attached to the governor control shaft (the thing poking into your crank case)?
if so you likely messed up it's orientation. (it looks like a hockey stick on the lower end)
Now, loosen the nut again, push the governor arm to WOT (clockwise) hold it in place
while doing the same with the governor shaft (should be slotted) until you feel it touching the governor wheel.
tighten the nut down again so they're fixed.
Lastly warm up the engine and adjust WOT rpm with the small limiter screw on the throttle lever (to ~3600rpm but no more than 3900rpm)
And you're back in business :D
Bnagy
Mont Belvieu, Texas
Ok. I did tighten the nut and make sure the control arm had the carb wide open, but I wasn't sure about the actual shaft position when I tightened it. I'll check that as soon as I get home. Thanks a lot for your input.
Thanks. That is what I was thinking too. But I did not know for sure how that works.
Bnagy
Mont Belvieu, Texas
Just got done with it. It worked like a charm. You're the man!
So to sum this all up it is similar to getting your Timing marks lined up when installing a cam.
