420cc engine for cheap..........
Joe-405
Enjoying New Projects
U.S.A.
After riding it I can confirm its the pos carburetor ! I can lay in it slow and hit 5000. I drilled my main cause it's running out of fuel I think but it's too late to try again tonight. And it's hard to test from a stop cause the belt is short and its direct drive right now. Lol. So I hope it wears in or stretches pretty quick like. Or I will get another belt next size longer from my work cause we can get the comet belts through rotary. Will order Wednesday and have it thursday if if doesn't straighten out his weekend during testing.
Joe-405
U.S.A.
So my buddy came over and after watching me ride it...............
We have came to a conclusion that its ignition somewhere. I havent pin pointed it yet but when i do i will let you guys know for sure !
Has anybody else even tried using one of these engines yet ? For some other feedback. Or am i the only one that removed the internal governor and tried it so far ?
---------- Post added at 07:13 PM ---------- Previous post was at 07:08 PM ----------
Does this make sense to anybody...............this is the specs of the coil
YAMADA 188F Generator High Voltage Set,Ignitor,Ignition coil
Technical Parameter:
1. Operating Temperature Range: (-30~105)C
2. Storage Temperature Range: (-40~120)C
3. Operating R.Speed: 250~4200rpm
4. Fly Wheel Magnetic Field Intensity: 1500~1900GS
5. Testing Term: situation temperature 20C, The distance between fly wheel is (0.4±0.1)mm and 3 pins is 6mm
6. Min. Continuous Ingintion R. Speed ≤250rpm
7. Min. Opening Voltage ≥12KV/250rpm;≥16/KV(1000~4200)rpm
8. Ignition Advanced Angle: (22-25)°/(250~4200)rpm
9. High and Low Temperature shoke: Between (-29~125)C, every degree for one hour and after 25 cycles, the original function keeps above 90%
10. Endurance Performance: the temperature 85C and R. Speed 3600rpm, after sontinue 150 hours operating, the original Performance keeps above 90%
11. Open Circuit Performance: Temperature 85C and R.Speed 3600rpm, after continue 150 hours, secondary open circuit keeps above of 90% original one.
12. Shake Performance: 4 hours shock on tridimensional direction with strength 98m/(second*second), the range of frequency sweep is 50~500Hz and after 15 minutes, the original performance keeps above 90%.
Joe-405
U.S.A.
After a lot of thought....... Unless the coil is just straight junk it has to be carb cause I was reading the tach while riding it and it's not getting above 3k rpm at all. So I think my exhaust and air filter is requiring more air or timing.
Keep you posted but I ordered a elcheapo Koso 32mm carb, timing key, and adapter in hopes of getting to at least cruise around a little bit. If that doesn't work the coil or flywheel is definitely the culprit.
---------- Post added at 03:33 PM ---------- Previous post was at 03:32 PM ----------
As soon as you hit the gas hard it lays over.
---------- Post added at 03:33 PM ---------- Previous post was at 03:33 PM ----------
If you ease in it it still bogs and cuts out.
Have you tried asking around on the buggy forum?
---------- Post added at 04:09 PM ---------- Previous post was at 03:46 PM ----------
I started this thread for the FOUR or so of us that bought one.
http://www.buggiesgonewild.com/big-block-talk/121145-powerland-420cc-modifications.html#post1300980
Joe-405
U.S.A.
I dont usually like starting new forums unless its useful. And over there is public so its easier to google it. haha
From the above link.... Just sharing
"You must richen up the carb if you mod the airbox or exhaust, its a given or it wont run well. Some have problems with the plug get a ngk from NR racing or someone if you do. Mine still has stock plug in it no issues. If its lean you can put the choke on part way and it will run better, is how you can tell. Jet drill sets are $10 on amazon or get a torch tip cleaner and file it out.
The lifan has a rev limit coil you have to buy the honda replacement ut2 from NR to get rid of it, its the only one I know of so far.
Stock clone usually run about 4300 and float valves. Run about 5300 in a lifted cart with HD springs and advance key, give or take.
I recommend running 10 gal of fuel through it before you go over 4500 rpm to break them in. It took mine a while I could feel it."
aham2003
Cleveland, Tn
****. My only plans for this motor were intake, exhaust and governor removal. I can do valve springs, but all this other stuff sounds a little beyond my expertise. I have been into motors before, so im no stranger, but how hard is it to put a new cam and rod in one of these? Any tips or pointers that would help? Its sitting on the workbench now and its calling my name to juice her up.
Is a new carb required or was it the coil limiting rev?
I just spread internet speculation like herpes.
For all I know, these are Frankenstein clones with random parts.
Joe-405
U.S.A.
He has a point anything could be it at this point.
I got a jet, emulsion tube, low idle jet from my work out of a Keihin carburetor and at least this time it says what size the jets are on the side. Gonna try it when I get home from work. I don't now what it's from but everything seems to be the same as far as fit wise. I left the tube at home but the jets are the same. So everything should fit right in.
It's something stupid I'm sure. And I gotta get it to the 4300 first cleanly before fixing that issue. It doesn't even get there at this point.
I'm afraid to ask..... Because I'm too lazy to go back and read. Lol
BUT You did fire up this engine and run it stock before taking parts off????? It's too cheap to not test first, right???
Powerland Customer support is good from what I hear. They pick up ****** engines and send new ones to replace
I need to run mine first then before putting on the aftermarket parts.
I would. Just to test it out.
I'll hopefully break mine in for a few hrs with the governor still in, but who knows???
It seems logical, but it's really easy to take apart when you first get it open. Lol
Because of this site, I cannot spell break or brake without double checking every time :(
aham2003
Cleveland, Tn
Im probably going to take the governor off before the first crank and just make sure its got plenty of idle/low rpm break in time. Run a few tanks through it and change the oil. After that, ill test it out and if all runs well ill throw on the intake/exhaust/jet/6 degree timing key and hope for the best.
Joe-405
U.S.A.
Oopsey. Nope sure did not actually. I just talked to aRC racing and they said I have to drill out the idle Jet first and I kind of forgot to do anything with the idle Jet so I think that's what's wrong
aham2003
Cleveland, Tn
So with a stage one kit, you have to drill out the idle jet?
Joe-405
U.S.A.
Yep ! I can officially confirm that as of about oh say 15 minutes ago.
Air filter, exhaust, governor removal is all I got and it officially hits 5100 rpm. Thanks to ARC racing for their extensive and fabulous customer service. I drilled the main and the idle one time and it runs great. Running hot so im gonna go up a touch on the main to help but its running great.
And if you want gas mileage I suggest you to buy another engine !!!! :surrender:
aham2003
Cleveland, Tn
Pardon the ignorance, but which one is the idle jet? The stage 1 kit comes with 4 different size jets, but I believe they are main jets.
Also, the kit doesnt come with a bored out e-tube. Will that be an issue? Here is what the kit includes:
(1) angled air filter
(1) air filter adapter
(1) choke hold bracket
(1) gasket
(1) .041" (#104) jet
(1) .042" (#107) jet
(1) .043" (#109) jet
(1) .044" (#112) jet
(1) .045" (#114) jet
(1) .046" (#117) jet - try and see which you like best!
(1) 6 degree advanced timing key
(1) straight header
(1) gasket
(1) straight header
Those are all main jets.
https://www.ombwarehouse.com/Stock-Jet-Honda-Low-Speed-GX390.html
^here is the idle, but I'd just get the drill bits and go up one at a time on the stock one.
Maybe get 1 extra stock size jet in case you drill to big, then you can go back.
And how to get to it
http://outdoorpowerinfo.com/repairs/honda_carb_16100-zf6-w10.asp
I assume you can figure out how to drill it.
You can also buy Pre-drilled Pilot Jets, but I can't find cheap options right now.
aham2003
Cleveland, Tn
Thanks!!!!
Is the e-tube good at the factory setting? I noticed the kit didnt come with a new e-tube (like most 212 stage 1 kits do).
