Intake Manifolds
thebroketeenager
Bakersfield California
Hey guys (and possible gals :thumbsup:) I have a question for you. Has anyone had success with intake manifolds on a Predator with a stock carb? Ive messed around with them before and they were so finiky that I couldn't get the thing to run the same for more than 10 minutes. I dont have any pictures, but essentially it was these half pieces with pvc between:http://www.affordablegokarts.com/images/manifold/DIY-Curved-Manifold-2.jpg
I think my issue was that the mixture would condense on the cool pvc and make the engine run stooopid rich. Anyway I'm itching to try new things so any info is appreciated!:cheers2:
On my bike I have a Champion 6.5... I modded the intake to remote the filter and eliminate the air box. Esentially using that link as inspiration for my mod.
I did have to re jet, and I have to keep the choke on the half-cock position. It is finicky but as I got it now... Works pretty good.
Atlanta, GA
I guess I'll just ask: why? What do you think can be gained? Please don't say "horsepower". The carb is attached to the cylinder head. A manifold will just make delivering the a/f mixture harder and more complicated. Now if this was part of a carb upgrade, maybe; but again, if you can attach the carb directly to the cyl head you are technically providing the most optimal a/f flow.
I wanted to remote my carb because of the air filter, Id hit it with my leg. I cant find a smaller cheap one with out to much effort... I wanted to build something aswell so I went with this idea....
thebroketeenager
The noise, really. The one time I actually got my experimental intake to work, I got to gun it one time and it sounded like it was on fire. Like seriously it sounded like a dirtbike. Plus I'm on summer break w/o a job and I'm pretty bored.
Atlanta, GA
No disrespect intended, but get a job. It is an essential part of life and the sooner you start, the better a person you will be. In the USA, anything is possible.
thebroketeenager
None taken. I planned on getting a job at a local Papa Murphys but my school wouldn't give me a work permit. In CA at least you need one to get a job before you're 16. I also had summer school PE for 2 months, so that wouldn't have helped much because I would have had to go into work at about 1 in the afternoon.
Atlanta, GA
That's the spirit.
I came here looking for something I couldn't find anywhere else. Hey, I'm not trying to be nobody,
I just want a chance to be myself.
Did you flunk PE?
There might not be any help for you. LOLOLOLOLOL
