420cc engine for cheap..........
aham2003
Cleveland, Tn
I'm already ahead of you guys. It is a true 420cc. I think by looking at all the internals. It's whatever the company could scrounge up cheaper and put it all together.
After some 1/8 mile testing I'm buying a rod, flywheel, and a camshaft. So stay tuned at my build and I will keep everybody in the loop as to whether I can push it hard enough to blow it up. Because in about 2 weeks or so I'm gonna **** sure try ! All I did so far is remove governor completely, air filter adapter and new filter, and exhaust with a proper rejet by drilling the jet out myself. Everything else is bone stock.
So do i buy predator 420 parts or gx390 parts?
[/COLOR]Thanks Denny! This is your fault! I'm coming over and now you have to help me build something to put it on!! I may need a storage unit soon. And another job![/QUOTE]
Bring it on I have a bunch of equipment but you got to help me clean the shop out first. By the way it is 54'x80' and packed full. :thumbsup:
I'm going to call this guy at vegascarts.com about these parts.
http://www.vegascarts.com/category-s/1513.htm?searching=Y&sort=7&cat=1513&show=6&page=1
I just read a post on another forum.
"I can tell you that Ive spent nearly 20hrs a week since September, R&Ding these 420s and have gone from a stock 420 to a completely built 440 and pretty much every combination in-between. All of my testing has been done on the same white 1992 Club Car DS with 12" rims and 18" low pro tires, utilizing the same CPP clutches that I started out with. So I can assure you that my R&D was completely relevant to the subject.
Furthermore, I have had direct contact with Charles Mosley (minidragbike), Jeremy Parsons (Parsons Racing Engines), Russell @ NR-Racing, Shane @ Affordable Go Karts, and Tim Iskenderian (Small Engine Cams). These people are some of, in not THE, TOP Clone Engine builders in the country. Each and every one of them has led me in the right direction and they have all contributed to my 440 program in one way or another.
My goal was to develop an engine specific to Golf Carts, that was extremely affordable, yet also yielded massive power gains and maintained reliability and low end torque. The goal was to develop this platform and make it available for HALF the cost of a typical v-twin big block swap.
As of right now, I have 440 engines 2 weeks away, and performance parts 2 months away. I have used Parsons and Isky parts exclusively in the meantime to test the 420 & 440 CLONE engines that I have in house. These are the FACTS:
-Big Engines Like Big Cams , The bigger the cam I put in them, the more OVERALL HP and Torque they gained. I tested 7 cams, starting with a 220 Duration/.280 Lift cam. I ended up with a 260 Duration / .410 Lift cam that Isky ground custom for me. Every time that I went up to a larger cam, I gained more power throughout the ENTIRE rpm range. Iam positive that I could go even larger, however, I feel that the 260/410 cam is a great all-around setup and will serve as a dual-purpose cam so even the kart and lawnmower guys can use it. Eventually I will test some .500 lift cams, the real issue I ran into was clearance with the crank. This cam is .020" away from hitting as it is.
-7000rpm is the limit for the big blocks when it comes to reliability(they dont like to rev), thats the reason I stuck with stock size valves. The stock 35/31mm valves wont make power past 6500rpm anyway, the key to keeping these engines alive is keeping the RPMs down. Keep it at 7k or under and you will not have a reliability issue.
-Stock Clutches are good for stock engines, if you want to make power and use it, you will need to upgrade the clutch first. Stick with CPPs Clutch, its rated to 30hp. Im probably making 32-33 and its holding up just fine. You dont see V-Twin swaps with stock clutches very often! More Power = More Supporting Mods...Bottom Line
-A Built Clone with a Billet Rod, Hard-Face-Welded Camshaft, Stainless Valves, Chrome Silicon Springs, Aluminum or Titanium Retainers. Chromoly Pushrods, and Shaft Rockers, is going to be MUCH stronger and more reliable than stock. The stock rod flexes and deforms under high power, it also is a piss poor design for high speed lubrication and will gall the crank. I ran a stock rod and valves for ALONG time and ALOT of abuse. I didnt have 1 problem until the day I put a cam in it. Even the small cam was such a drastic power increase, the stock rod and valves ate the sheets within 4 hours. Stock valves are junk and cannot withstand the higher valvespring pressures of dual springs, so bottom line is, they dont call it a "Built" engine for their health. Its "Built" so it can RELIABLY take the abuse associated with a high horsepower application. Both ARC and Parsons rods have taken tons of abuse on the go kart tracks which are significantly harder on any engine than a Golf Cart is. 6500+ rpm for 30 mins at a time.
-Dyno numbers mean nothing! I have a drag mustang that makes over 1200HP but it only makes 700rwhp on a chassis dyno. There are too many variables to consider with dynos, so its really a waste of time trying to compare them in any way, especially when considering two different setups. I tune clone'd golf carts based on feel, its not like we are drag racing and trying to get every last .01 of a second. All we care about is that the cart starts easily, idles smoothly, and pulls smoothly through the whole rpm band without issue, and of course...it must pull really hard, and do big wheelies :)
I would continue but Im very hungry at the moment and dinner is ready. I hope to post some good videos this weekend but I just havent had time lately. Im anxious to get the built engine'd cart on youtube. Its way past the point of being safe and is really cool seeing as how you can get soo much power into a stock height cart, no lift kit needed(HUGE advantage of clones over v-twins.)."
With regards to bang for buck, a 420 clone with the following mods will make 20-22hp and doesnt need a billet rod:
-Timing Key
-Ported & Milled Head
-28-32mm ATV/Motocycle Carb
-Header & Free Flowing Exhaust
-HD ValveSprings
Can be done for $400 including the engine.
-Geoff
-Geoff Warner
702-335-4002
Well he put his phone number so I guess he doesn't mind you reposting it to the inner web!
I must be too hot and tired to sleep I actually read your long post, (I never do that).
Cool and interesting stuff. Sounds like Jeff or is it "G-off" Joffry? whatever, guy knows his stuff.
Atlanta, GA
You probably got that off BuggiesGoneWild, right? The amount of information regarding big block clones over there is amazing.
Correct. But sometimes I try to not be too specific as I don't know what the feeling's are about linking (promoting) another forum.
I'm all for the spread of information, but still want people to know that THIS is the best forum. So I'll copy and paste it here. :thumbsup:
I'm NOT moving to the golf CART forum, I'm staying right here with you. You can't get rid of me that easy!! :rolleyes:
Joe-405
Enjoying New Projects
U.S.A.
I called Vegas karts................ ONCE. Never again. If it's not a golf cart they won't talk to you.
---------- Post added at 01:37 PM ---------- Previous post was at 01:35 PM ----------
Haven't tried internal stuff yet. Gotta blow it up first. Lol
But all the external stuff is gx390.
MrC.
florida
So lets be clear.
Is the Powerland 420 a good engine?
Is it as reliable and strong as the predator line of engines?
I am thinking about upgrading from my 212 predator which I love. Is it a noticeable difference between the 212 and powerland 420?
I understand the output shaft is 1 inch vs 3/4. any other pro's or cons to this budget engine?
Thanks
MrC.
So lets be clear.
Thanks
MrC.
More torque with 420cc. (Say 20 ft lbs over 10 ft lbs)
More RPM with 212cc (say 5400 over 4500 Rpm.
Clutches and TCs are more expensive for 1" shafts.
Because of the Lower RPMs and extra torque of the 420, it needs to be geared differently.
If you LOVE it now, why upgrade?
---------- Post added at 11:22 AM ---------- Previous post was at 11:19 AM ----------
So lets be clear.
Thanks
MrC.
Is any cheap Clonda clone a good engine?
PL420 is probably just as good as the Predator 420. Clones are made by cheapest bidder. Probably rolls off the same assembly line?
There are some Clones that Do roll off the same assembly line as a genuine Honda. I have even seen big labels on the boxes on ebay that say GX160 etc.
But the Powerland and the Predator are not true clones. Internal parts do not match. They are copies.
Joe-405
U.S.A.
I have had mine completely apart. The pl 420 is almost dead on with a gx390. I work in a small engine shop and have seen both apart.
And FYI if you take the governor out and thats it 4310rpm is all she wrote and it acts like it hit a really stout rev limiter or 2-step. Havent rode it yet but i held it wide open and she definately hit the "rev" limiter thats not there anymore ! Cause i pulled the governor out.
Based on the Rev limit. Would you guys suggest a GX390 then. Or does it have that also?
Joe-405
U.S.A.
Its not the coil that's stopping it too is it? Read about using a non gov coil for gx390s.
It's possible. I will do that next to see. If anybody else has tried speak up !
---------- Post added at 09:58 AM ---------- Previous post was at 09:42 AM ----------
It's the coil.
From what I read. You need 35 lb HD springs to get over 4500 RPM with these Big Block clones.
Are you bouncing the valves at 4310?
---------- Post added at 11:00 AM ---------- Previous post was at 10:59 AM ----------
Was FREE RUNNER CORRECT?
4K REV LIMITER?
IS THIS THE ELECTRIC VERSION?
Joe-405
U.S.A.
4K REV LIMITER?
Definitely not floating valves. It literally hits a limiter.
