Help! Torque converter all wrong
Eric87
Good call, I just pulled the trigger on a 44 Magnum Driver from anazon It's should be compatible with my backplate.. anything larger and I need to weld up a plate for a jackshaft and use a Snowmobile setup.
I think they gave me something rated for 20 or 30 series and labeled as 40 series...Ebay sellers:mad2:
---------- Post added at 08:36 PM ---------- Previous post was at 08:35 PM ----------
Where'd you find that? I'd like to get one to have in hand for future nods
You don't need the 44 magnum . You just need a proper 40 series TC on a jackshaft. The jackshaft plate pictured is found on a manco go kart.
BigMark408
BigMark408
Portland, OR
I thought that was a Powerland, you said Predator though. Can you post your Amazon one?
Eric, how can you tell series of TC by pics?
I'm noticing you CAN tell difference in pics for different series.. i cant tell 20 from 30 but i dont use em anyway lol... the give away seems to be the outside face designs but i could be wrong.. i see that big nut on the outside of the 40's but not 30's, the 44 is obvious, the Comet 500 is very distinct and the 94C unique in its design as well.
i'm 100% that they sold me a 30 series labeled as 40..
Some examples of what i have found for visually knowing from pics... someone correct if i'm wrong on these :2guns:
Eric87
Appears to be, a 40 series clone at least.
Same as the one you posted .same as the one I posted pic of.
---------- Post added at 12:59 PM ---------- Previous post was at 12:58 PM ----------
Just diffrent shaft sizes
Eric87
This was my mistake when buying, oh well **** happens.. lessons learned the hard way.. story of my life :lolgoku:
Hey I just bought a dingo with a 10 hp on it . It has a 30 series on it . Guess what I'm buying . The guy selling it said it ate a lot of belts.
The 94c and 44 series were designed mainly for 2 stroke applications and suck for 4 stroke applications. You will have trouble getting a low enough engagement and then up shift. Just my 2 cents.
Sorry Denny, but that's BS..
the 44magnum's engagement is between 1600 RPM and 3100 RPM.
the exact same as the series 40!
JUST perfect for a four stroke engine..
(the series 30 is between 1400 and 4400 rpm barely able to be mounted to a 2stroke engine)
the 94c clutch engage from as little as 1450 to 5800 rpms (and yes, that should be enough for a two stroke as well)
see the chart:
but yeah... Sorry but your claim is plain wrong.
BigMark408
BigMark408
Portland, OR
This setup has proven over and over on four stroke applications so I'm sorry bit I will also have to say you are wrong on this. The same speed rating for clutch engagement is for the 30 and 40 series and thy can hold up without issue if power raring is properly matched or you will be eating up the clutch and belts.
I also reached out to Comet themselves by way of Ombwarehouse.com and they verified everything I have now to be correct for my application.
see the chart:
Sorry Sid but if you have ever tried to tune a 94c for a 4 stroke you will see I am right. Pain in the a$$ to tune, it can be done but you will not be happy. There are a lot of other golfcart guys out there with the same opinion as me. The 94 series was originally designed by Commet as a cheaper replacement clutch for 2 stroke golfcarts according to a factory rep I talked to many years ago. Yes, I was mistaken about the 44 series though, I just hate those. If you over rev them the pucks fly out and hit you in the face and you poop you're self. :smiley_omg:
BigMark408
BigMark408
Portland, OR
Get everything lined up, drilled, cut to fit and finally installed. Finally she's READY!!!
All The Goodies:
PowerLand 420cc
OMBWAREHOUSE stage 1 Header & Muffler
Vegaskarts Tuned/adjustable 30mm Carb with jet kit
ARC racing Billet Carb adapter with Angled air filter & prefilter
Governor removed w/direct throttle hookup
Crankcase and fuel tank breather
Comet 44 magnum Drive clutch
Comet 44 driven 8.5" Driven clutch
Maxtorque drive belt
3/4" jackshaft
Carbon steel 9T sprocket
Stock 70T axle sprocket
#40 Yamaha Drive Chain
22" ITP Mud Lites on stock 8" steel wheels
2x 13" Adjustable Coilovers w remote reservoir front
2x 16" Adjustable Coilover rear
Hydraulic brakes w drilled stock rotor
BigMark408
BigMark408
Portland, OR
Well no video again but the buggy does incredible in mountains now. The torque is Unreal, actually tore a Carbon Sprocket in half on a hill climb (9T) and swapped out to a 12T with a casing 5X as thick.. happy trailing after that and showed up a Jeep CJ on a massive gravel hill.. Epic
BigMark408
BigMark408
Portland, OR
The Carnage
:thumbsup:
So now we are happy with 70T, 12T, 22" Tires, and 44 8.5" TC?
I'm not trying to copy or anything? Maybe I am. That's actually what I do!
