Help! Torque converter all wrong
BigMark408
BigMark408
Portland, OR
PLEASE!!! I Need help finding correct setup.
I have a Baja SD65 Sand Dog go Kart Buggy with a lets say 20hp/20ftlb 420cc predator engine and i need help finding correct torque converter setup for my new engine swap.
kart weighs 420lbs... currently 40 series Torque converter w 8T on JS to 70T on Axle... 22"tires
the Ebay crap i have isnt going to work, So i want to know if anyone has used a Comet 500 or 780 clutch? i'm trying to get away with using the same backplate so i dont have to weld up an entire jackshaft assembly and spend another $100-200 on parts and tools...
looking at 44 Magnum Clutch
Comet 500 Series
Leaning towards a 780 series
TonyMontana214
Dallas
wait so is the 40 series not enough or did you burn through it. Im planning on using that with my 24 hp honda vtwin. so if yours cant handle it then i have to think about using it
Eric87
Something like this with a 40 series on it
Eric87
I don't see a 40 series in those pictures . I see a tav 2 30 series.
BigMark408
BigMark408
Portland, OR
You need this TC
Good call, I just pulled the trigger on a 44 Magnum Driver from anazon It's should be compatible with my backplate.. anything larger and I need to weld up a plate for a jackshaft and use a Snowmobile setup.
I think they gave me something rated for 20 or 30 series and labeled as 40 series...Ebay sellers:mad2:
---------- Post added at 08:36 PM ---------- Previous post was at 08:35 PM ----------
Another jackshaft plate
Where'd you find that? I'd like to get one to have in hand for future nods
Jfive
Great falls Montana
I'm gonna make some jackshaft plates. Read that 40series TC really need two bearing points not one like the engine plates have. I'd do a jackshaft setup personally. Not sur how much he wants but jack shaft Johnny has some nice ones on youtube
Jrgunn5150
Rudderless
There's a 30 series floating around, a "Blast" I beleive? Masquerading as a 40 series. Any standard 40 series should work fine, like this,
http://www.ebay.com/itm/40-Series-T...757260?hash=item5b2077f88c:g:xa4AAOSwll1Ww29F
If you pay less than 100, you're gonna eat it.
cavfire
auburn, georgia
The Comet 44 driver uses a symmetrical belt, but the driven on your current setup uses a asymmetrical belt. Suffice it to say you're going to need to pick up a 40d driven unit to work with the new driver.
I don't have complete trust in the TAV2 backplate either with the torque of a 420cc. I broke one in half with a mildly built 196cc by flooring it while rolling backwards a little on a hill. Yeah, probably not the smartest thing I've done :roflol:
BigMark408
BigMark408
Portland, OR
I like the BMI jackshaft mounting plates with the pillow hangers for 36 bucks, I'll order a longer jackshaft with it.
I know the 44 Magnum is symmetrical but I have a max torque 3/4 bore symmetrical 8 1/2" Driven that I have been holding onto.. it will work perfectly with the new driver on the way... both use 7/8 belt
father87
Miami, FL
I thought that was a Powerland, you said Predator though. Can you post your Amazon one?
Eric, how can you tell series of TC by pics?
BigMark408
BigMark408
Portland, OR
It is a Powerland but Predator is same difference in clone aspect and more commonly known for conversation purposes.
Found this thread: EXACTLY WHAT I'M DOING!!! Awesome to have some photos for reference now...
http://www.diygokarts.com/vb/showthread.php?t=12946
Eric87
40 series has big nut on driver .30 series is flat on one side inside the pully.
