Another TC problem thread...let's get all the problems fixed this week!
JollyKarter
Texas
Well, I have a torque converter issue that hasn't been addressed in the last week, so let's throw it in and maybe we can fix all possible TC issues in a week!
I have a Yerf Dog with what I am assuming is the original Comet 30 on it. I don't know if it is shifting and moving just like it should, but it works well enough. The major issue I am having is the clutch in the driver stays engaged after extended periods of riding. When I come to a stop, it is locked up. It had gotten to the point that it would kill the engine, and after a moment I could restart the motor and the clutch would release. I took the driver off and cleaned it up. I used some Emory cloth to polish the inside of the outer cover and the belt surfaces. The garder springs are in good shape, they are not straightedge straight, with just a hint of bend in them. The weights had a wear spot on the middle of each of them. I gave them a good polish also, as well as the pins. The inside of the hub was clean and smooth, and the bushing it rides on got a good polishing as well, and slid nicely with no bind in the hub.
After cleaning and polishing, it still acts up after an extended high speed run, but a quick gouge on the brakes is usually enough to knock it loose so I can stop.
I am wondering if I need to just replace the driver, or if there is something I am missing. I didn't have any graphite on hand, so I reassembled dry. I need to pickup a can, and when I do I will probably disassemble and give it a lubing...do y'all think I may just have a lube problem, or could it be something more of a wear or fatigue issue? If the driver is damaged and needs replaced, I am thinking it may be best to just replace the entire setup. My concern is on the Yerf, the jack shaft is attached to a plate that fits unter the motor, I am guessing that is too keep proper spacing for the TC setup. Are the knockoff kits direct replacements for the actual Comets? The belt is starting to show wear, so I am figuring on replacing it soon, and if I need to also replace the driver, I figure the eBay kit would be a cheaper alternative to piecing together Comet parts. Any thoughts from the Karting masses?
Btw...no longer running the original Tecumseh. It had carb issues when I got the kart, and I had a good 6.5 hp Briggs Intek 206 laying in the shop, so I slapped it on. It has the same issue as the Predator swap onto a Yerf...it has a shorter crankshaft, so you only have a small amount of the crank that the driver sits on.
Staff Murderator
Man, you are a verbose character. Was this due to an extra pot of coffee? :worried2: :)
My advice is to learn all you can and invest in inexpensive Chinese TCs from Fleabay as viable alternatives. As for repairing what you have; it's a good idea always so you can poke your fingers in the eyes of the current trend, which is to be just a parts replacer and not a diagnostic, fix-what's-broken mechanic/technician of the bygone era. I go by the adage, "if it's easy it's not worth doing".
JollyKarter
Texas
My concern has grown...checking the bmi site, Comet lists a TC kit specifically for yerf dogs. I guess after the Holliday I will have to get on the horn and try to figure out the reason for that and hopefully if full replacement is required a knockoff will do...the Yerf kit was not cheap.
Not trying to be verbose, I just don't want to leave out any details that might be asked for later on.
I thought you were very clear and not at all "Verbose". Why not just get it all out there instead of 10 questions all with your response being "yep did that"
Hellion just likes to use obscure and brobdingnagian words to confuse folks!
Well.. Jolly check your weights again; especially the slide rods that they have..
if one is bent or able to move it could prevent contraction of the weights.
Also the garter springs should snap back perfectly straight.
So to be sure measure their length
if they're longer than 7 7/8". (even only one of them)
they'll need to be replaced.
(blue one's.. mfgsupply.com is cheaper than most other sellers)
and yes.. drylubing the inside of the driver bell and mabye a slight mist on the weights can make things much easier.
so get some drylube as well.
JollyKarter
Texas
I did not think to measure the springs. The weights seemed to slide on the pins well. I noticed I can buy a new weight and spring set from BMI, and that may be the best plan of action if lube doesn't do the trick.
No really it is...Hellion is a real word....I looked it up...it's a troublemaking or mischievous person...especially a child.:lolgoku:
Are you that Gulliver Bob?
Oh come on. There's no way that world is real. Not looking it up!
Brobdingnagian:
adjective
1.
of huge size; gigantic; tremendous.
So are you calling me a prevaricator? I wouldn't $#it you, your my favorite turd!
Brobdingnagian:
adjective
1.
.....And the name of the land in Gulliver's Travels..(but if you look closely at the ropes they tied him down with.....they decided to GAB on that!)
Staff Murderator
Hey Sid, if Jolly wants to spend his money and even more for outrageous shipping charges at BMI, you should not interfere.
Bob said that "world" cannot be real. Question is, what world is he thinking of? If it's Brobdingnag I'm impressed.
That is why we are here, To save each other from Mistakes like shopping at :surrender: BMI! Jolly is in Texas, he should be shopping at GoPowerSports.com In Keller Tx and saving 10% with the DIYGOKARTS coupon code!
I am wondering if I need to just replace the driver.
Could be that someone else could do a better job....
See....we can play with words all day....:lolgoku:
Nope. Not that smart, nor well-read. I only make typos. But you can see, even my mistakes are very sophisticated and over my head.
JollyKarter
Texas
I looked at the GPS site, didn't find just the weights. From just moderate research and shopping, it looks like the typical Comet 30 comes with a 6" driven and the Yerf comes with a 7" driven, something about compensating on the bottom end for the 18" tires. I gused my first plan of action is lubing the driver/clutch, and I guess if that doesn't work buy a weight set. I am definitely not married to buying from BMI, just started searching there since they seem to have alot of Yerf specific parts.
