TC question
aham2003
Cleveland, Tn
I am restoring a Baja mini bike and plan on using a TC on it. I am going to be running an ungoverned 212 hemi with stage 1 kit. The kit will have a 10 tooth sprocket on the TC and a 50 tooth sprocket. Does the BMI gearing calculator work for setups with TCs? If so, according to it, I will get a top speed of 61 MPH at 5400 RPM.
Also, what is the difference in a 20 series and a 30 series? Which one would be better for my application? Thanks.
the series 30.. the only one you can buy a TAV-Kit for these days anyways..
it comes with a nice 10% overdrive and you'll have the best bang for the buck.
Now.. 61mph is likely NOT achievable;
since no.. nearly all calculators out there do NOT take weight and drag into account;
they only calculate the rpms and the ratio to calculate wheel rpms and thus speed..
which is a lie (as soon as you get into realms of 50mph or more without having the necessary power to get there)
Also doing 60mph on a minibike.... frankly sounds like your signing up for a darwin award buddy;
go for acceleration not topspeed .. you'll have way more fun that way ;)
since everything above ~30mph will feel like 120 anyways :D
PS you can try my calc if you want.. open
app.kartcalc.net on your smartphone and punch in some numbers as close to the real live values as possible.
[Hint: check the settings first.. weight by default will be in kilograms not lbs!]
Distanced travel per revolution in feet = (Tire Diameter in Inches/12)*3.14
Final Gear Ratio with 30 series TC = Gear Ratio *0.9
MPH (with 30 series)= ((RPM / Final Gear Ratio) x (Dist travel per rev in feet) x 60) / 5280
Darwinism is real. Blessed are the cockroaches, for they will inherit the Earth.:lolgoku:
Sorry ^ guy started it.
Joe-405
Enjoying New Projects
U.S.A.
that sounds correct on gearing. My barstool has about the same setup.
And bmi sells a clone 30 series for about $120ish......It will hold just fine
Joe-405
U.S.A.
