Trailmaster MB200-2
Tman
Bought this from FamilyGoKart. BIG mistake. Been waiting a month for parts that were damaged in shipping. Carburetor is messed up low speed plastic jet was damaged. I've have emailed them and get no response. and no one will talk to you on the phone unless your buying something. it came with a 6.5 HP engine that says 168F. Does anyone know who makes this engine and where to get parts for it. I need that jet bike will not run. Carb says manufactured in japan but carb name has been ground off. any help would be great.
ML-TOYS
long island, new york
So if you go to their site look up your bike and theres a support link that has a parts link. Get the carb number and google it. I will continue to tell you what to do but you should figure it out from there.
btw for $750.00 they should have some good customer service
When I searched 168F.
I came up with a Lifan Engine?
I think it is a Honda Clone. Carbs are about $13 I believe.
Ya I was thinking this would fit (95% sure)
http://www.ebay.com/itm/Carburetor-...00-/281781776856?_trksid=p2141725.m3641.l6368
---------- Post added at 12:09 AM ---------- Previous post was at 12:04 AM ----------
The jets are cheap too, but with shipping maybe just buy the whole carb?
http://www.bmikarts.com/Low-RPM-Carburetor-Jet-for-65-HP-Clone-GX-160-or-GX200-Engine_p_119.html
$6 free shipping (just the jet)
http://www.ebay.com/itm/like/262430687113?lpid=82&chn=ps&ul_noapp=true
Tell the truth... How did the jet get damaged? lol
You can find parts for that engine everywhere online. Search 6.5 HP clone engine and boom!
Tman
Thanks to all for all the help.
I bought both these jets and they do not work The little plastic ridge pattern on them are off just enough to where they won't seat. The company just emailed me and said the would send me a new carb because you can't order carb parts singly. Also this is not the lifan engine i was told this by a company that sells Trailmaster gokarts and their mini bikes. He said they are shipped to them by Trailmaster and the have no idea who makes these engines. I asked if they would give me Trailmaster number so i could ask who make your engines. But no phone number was given to me. If they would call the company and ask, case solved but they won't for some reason. No i didn't ruin the jet the end of it looks like the brass jet hole was never put into the plastic. Manufacturing defect probably. And the Honda GX200 and GX160 are not the same engine as mine. Should i need other parts in the future i heed engine manufacturer to cross reference parts so i don't have to get them by mail all the time.
---------- Post added at 09:15 AM ---------- Previous post was at 09:07 AM ----------
All you can buy through them is the entire carb. Mine has the torque convertor not the centrifugal clutch. I could have bought a Baja locally but its a hard tail with a centrifugal clutch for 699.99 I prefer the the trail masters shocked ride over the Baja's back stiff hard tail. Plus everyone who buys A Baja or similar bike ends up changing over to a aftermarket torque convertor
The aftermarket idle jet I ordered did not have the brass fitting (all plastic) and It was also snug. The O-ring is a little bigger. I didn't think it fit at first, then I pushed harder and it went in. Not saying works for you, but I almost thought I got the wrong jet.
cavfire
auburn, georgia
Tman I had the same thing happen with a pilot jet not seating due to OD of jet being a tad too big. Chucked it up in a drill and hit it with some 220 grit sandpaper on the last ridge to get it to fit. O-ring seals it anyway. I'm with Bob though, whole carbs are under $15. Think I got one off Amazon for $12 or $13.
Tman
Carb on the way.
Thanks to everyone for the help. the place i bought it from is sending a new carb. I don't know why they are so reluctant to call trail master and find out who makes engine or give me the number so i can. Asked 4 times no response on that request. emailed 2 other company's that sell the same mini bike and asked about engine also. same response don't know we get it from trail master. Here's a clue CALL AND ASK. AND IF YOU DON'T HAVE THE GUTS TO GIVE THE THE NUMBER. its not that difficult. Thanks again.
Tman
not sure if Lifan
All lifan engines i've seen either say Lifan on them or have the LF with 168-1 or 168-2. mine has none of this it just has 168F. All Lifan's ive seen on internet have the above mentioned marking on them saying they are lifen. i have foend a couple that look exactly like mine but no pictured give any manufacturers names. if it was a Lifan you think it would show some of the Lifan markings.
