Starting issue
Coopiedog
So i got a new Predator 212. It won't start. I pulled the plug and got a nice blue spark on the first pull, but every subsequent pull, no spark. Any Ideas? I will try anything, if no help, its off the the small engine shop. Thanks.
Hello and welcome.
If it just on the ground(or not still good)... unplug the oil sensor on the side of the block. remember to cover the wire that is attached to gold little box as to not allow it to ground the motor.
Does it have compression?
Is it set to ON position....
Is there gas?
Post some more info and maybe a pic as to what its on...
Joe-405
Enjoying New Projects
U.S.A.
If it's new I would personally call the seller and exchange it for another new one !
Staff Murderator
Don't forget to break it in properly--don't just run off karting with the thing and never change the oil after the first 20 minutes or so.
Don't bring it to an engine shop. Exchange it. But first steal the gaskets, If you can get away with keeping the head... my address is 1600 Pennsylvania Ave.
kidding... Check the wires by the on/off switch. How much oil? (like 16 oz?). wait a few minutes after adding oil.
That would be kinda hard, since it wont start! :roflol:
What was that you said about reading comprehension?
Staff Murderator
I reserve the right to post any non-sequitur comment of my choice. My reading comprehension, grammar and spelling is fine though, unlike some people...
I reserve the right to post any non-sequitur posting of my choice. My reading comprehension, grammar and spelling is fine though, unlike some people...
I don't even know what that means, but you sure sound smart!:lolgoku:
Actually I do, however nugatory it is!
Staff Murderator
You said you have a nice spark at first. Do you also have fuel and compression (all the time)?
Since Predators are notorious for starting on the first pull, you should have a sputter, at least, as that first spark is going to ignite the fuel/air mixture. Signs of life, no matter how small are good.
Definitely make sure it has the proper level of oil--don't just assume. Mckutzy is on to something with the low oil sensor...
Yes...I don't usually like to parrot information....(unless the proper advice doesn't seem to resolve the issue.....but...YES!)
For those of you that were around...FR's video of cranking his new Predator for 50 times is a classic: "Turns out it was low on oil....."
I only say, if it on the ground and your holding it, as you pull it might tilt and trip the sensor, causing the trigger to keep it off.
