Torque converter questions
trkk11
New Lenox, IL
Hey all, it's been a while. My Yerf Dog project got put on hold due to a few big expenses over the past year, but I'm trying to get back into it now...... I'm looking into putting a correct torque converter setup on it, but have no clue because a previous owner removed all of the torque converter components and ran a clutch straight to the axle sprocket. I found 2 different ones on ebay from a reputable company, but I'm not sure if they'll work. The only difference I can see is these have 6 inch driven clutches and the kart is supposed to have a 7 inch.
http://m.ebay.com/itm/271891077636?_mwBanner=1
http://m.ebay.com/itm/301653709860?_mwBanner=1
Can anyone tell me if either of these will work on my Kart? And what would be the effect of going 6" rather than 7"?
Kart is a Yerf Dog 3202, and I'm putting a 9hp Honda engine on it. Thanks
Atlanta, GA
Those TC's are both rated for max 8hp. You can use them, but invest in the company that makes belts.
but you have a yerf dog that originally came with a 7" driven..
and that does indeed make a difference.
A series 30 with a 6" driven has the following ratios (LOW | HIGH)
2.7:1 | 0.9:1
a series 30 with a 7" driven has these ratios:
3.13:1 | 1.12:1
which doesn't sound like much, but at the already blurry edges tinkering with ratios, that can make a big difference.
So if you want to go down the easy road:
buy the 6" driven.. a new belt (you'll need it, since you should use the original jackshaft rather than the backplate anyways)
and improve your axle sprocket
...if you have a 60T sprocket now, you'll need a 70T in order to have the same takeoff torque;
well the imporved torque of the gx270 will likely make it a little less.. say ~66T
(to calc multiply your toothcount by 3.13 and divide by 2.7.. then round up to a whole number)
Or, go to mfgsupply and order a series30 7" driven (which is as expensive as the complete TAVKit at ebay I'm afraid)
either way you'll need a new belt (a longer one) so measure the center to center distance and order a belt..
again mfgsupply, or http://gokartsupply.com/tcbelts.htm
Very true;
But keep in mind it's a series 20 NOT a series 30 so it'll be incompatible with the TavKits from your first post.
