First welds! what do you think?
r_chez_08
Should be in the shop...
Cornwall, UK
These are my first welds. whad do you think
i wont be offended if you say they are totaly ****:roflol:
the second one is so big because i made a massive hole!
i am using a stick welder, i dont know what rods tho.
newrider3
Colorado
Not much of a weld going on there, mostly gobs of filler. Practice on a piece of plate. Make sure you get your welder on the right settings. Remember to watch the puddle, and go nice and slow.
r_chez_08
Cornwall, UK
i made a hole because the stick sticks sometimes, and if you turn up the heat it works again. only i forgot to turn the heat back down!
Raywelder
Not an Adm¡nistrator
Oh, your stick Welding!? You need a little mig, Much easier to learn on :thumbsup:
And I think You usually use your stick welder for bigger thicker metal. A little $200 Flux core\mig wire welder Will weld that up alot nicer.
Kenny_McCormic
Kartless....
Michigan Troll
You just use smaller rods working on smaller stuff, what do you think people did before wire welding got popular? They either used small rods or used an oxy torch.
kibble
I banned myself
r_chez_08, do what Newrider said about practicing on a plate, make some welds side by side at different settings so you get an idea of what setting does what. I wouldn't try to weld the kart together until you're comfortable that your welds are gonna hold up.
Nu uh! They rubbed the metal together really fast until it melted and fused together.
r_chez_08
Cornwall, UK
:roflol:
i dont have $200 to spend, especially as my kart is almost fnished.
p.s. i think i am using 2.5mm rods
pps. my dad rewelded the mess i made in the 2nd pic lol!
fluxcored
That revelation came to me after paying a small fortune in nozzles,tips, gas rental, etc.
You'll be amazed at how thin you can weld with a stick welder - if you set your mind to it.
You'll find that you'll do a lot better if you ran a few beads on a practice piece lying flat.
All welding should be fun!!!!
r_chez_08
Cornwall, UK
i did practice by writing my initials on some scrap iron, and then i ran out of room, so started on the kart!
