Another whatsit
Denyingchaos
Marion Ohio
I'm not sure about the seat...there is a metal frame that attaches to the seat which attaches to the floor pan. The mounting holes are matching and factory elongated so it can be moved forward. Again I have no idea what this kart is yet to determine if it is or not.
As for paint removal I want to stay away from chemical on a project this size. I was thinking high speed drill with wire brush attachment . Now wouldn't an angle grinder dig into the metal or are there softer discs out there? I hate to gouge or weaken the frame.
I would just smooth the rough spots and paint over it.
Unless you figure out this kart is indeed some rare classic vintage kart.
Father87 is in the process of stripping paint and he mentioned what a pain it is.
All the round pipe and welded corners. If you are real patient and diligent go for it.
Otherwise not worth it to me. just my 2 cents, worth nothing.:thumbsup:3
[edit] Angle grinder with wire brush
Denyingchaos
Marion Ohio
That's what I was thinking as well. I doubt it's something rare. The person who had it before me decided it would be awesome to paint over rust so I mainly want to take care of it and make sure there isn't any other hidden wonders I need to worry about. Sounds like a plan either way.
I can't help but say it.Check out the awesome power of hand sanding with sandpaper. And a wire wheel. on an electric drill motor....
I know.."drill motor " sounds a little funny..but google it up...
I used to use a drill but they're geared more for torque than speed. The angle grinder is a godsend--the real advantage is the RPMs you get out of it which is 10,000+. Makes quick work of rust and paint.
There's different types of wheels though. The typical wire wheel is probably the best and it is pretty soft for grinding steel--it doesn't score it deeply, just leaves a swirl pattern that's seen more than felt, sort of like brushed stainless steel. Then there's very aggressive twisted wire wheels. I've got one but haven't tried it yet. They have brass wheels too which are definitely softer and non-marring. I haven't tried the cup style in any material as of yet.
I bought my 4.5" grinder from Horror Fright because I'm not interested in spending hundreds of dollars...
---------- Post added at 01:55 PM ---------- Previous post was at 01:48 PM ----------
Father87 is a beginner and if he's not an "old hand" at this type of thing, the normal response is definitely going to be, "this is such a hassle". People today have no patience. These go karts are small little items--it's not like we're trying to restore the SS United States. If you want to see something sad, Google up that rusting behemoth eyesore whose fate is forever tied up in limbo.
Denyingchaos
Marion Ohio
It's not going to be too bad. Just tedious. Just takes a little time. I'm not trying to rush it and I'm soo glad it's not the USS United States . I use to work for Peterbilt Body shop way back in the day. I have seen some turds. Although I use to run parts I seen those guys go through **** on some of the stuff that came through there.
