torque values
pearl111
Baltimore, Maryland
Hello I should of asked this question on the last post. When I put the valve cover back on is there a torque lbs. speck I should use or just tighten carefully. If I were to gusstamate I would say I should do this carefully. I thank everyone for all the help I have been getting along the way so far. mike.
Tight is good.. But as I can tell, no torque value has been given for that...
Tighten evenly like a four(4) bolt tire...
cavfire
auburn, georgia
These would be my normal two recommendations that I'd tell someone at work, for reference I'm a Maintenance Manger in a plastics plant.
Tighten all four up evenly in sequence until one of them strips the threads or shears the head off, then back the other three off 1/8 turn. This is the one I give for small fasteners. On large fasteners, the torque spec is a three foot cheater and two grunts.
Luckily no one follows the advice on small fasteners, and neither should you! Personally I use a 1/4" ratchet held close to the head and snug them. The valve cover gaskets I've gotten were a thicker cork material that compress and seal pretty good without having to crank down on the bolts.
pearl111
Baltimore, Maryland
poboy kartman I filled out the map location appl. I hope it work out this time. I tried several times before could not get it to work. I hope the map location is what you met by location profile. Please help if I got this wrong. I enjoy this site forum and all the help and information and I don't want to lose my membership. mike
Nope...just go to "Quick links" and fill out your profile!
---------- Post added at 05:32 AM ---------- Previous post was at 05:26 AM ----------
I nominate this for drivel of the year award!
I'll go out on a limb here...first off: IT DOESN'T REALLY MATTER!!! JUST SNUG THE BSTARDS DOWN! But just "off the cuff" ....15-18 foot pounds!
pearl111
Baltimore, Maryland
Ok now that i know what to do I can get that info done butt wright now everyone is getting up. I intend on doing this first chance I get. mike
pearl111
Baltimore, Maryland
Hi there I think I got the profile location filled out ok. Let me know if its not wright I will try to fix it. I don't want you to Grab A Pabst Blue ribbon (GABP) this early in the day. Well a guess that might be a good thing when your trying to help me get through the forum basics. mike.
I like this guy! GAPB!:lolgoku::lolgoku: LOL
