getting more power
junker
I have a 5 hp tecumseh engine on my kart and i was wondering does anyone have any ideas how i can get more power out of it without spending much cash
motor_head
expert garbage picker
sutherland IA
go buy a dremel dewalt sells a decent one for $25 then you can port and polish should gain a couple of horsepower
Raywelder
Not an Adm¡nistrator
Port intake and exhaust, Run a straightpipe and You could mill the head down a bit for more compression.
theo
Put on a aftermarket aircleaner, rejet the carb and install a 5 deg key in the flywheel.
theo
modelengineer
Lord of the noise
Sydney, Australia
Ahhhh... no it wont. It's a good idea, but won't have THAT big of an effect. A few tenths of a horsepower, maybe.
All ideas so far are good ones, just don't expect to get more than about 7hp from accessories and polishing.
Affair_driven
BULL DETECTOR
Wolf Point, Montana
A little?
Getting that kind of power out of a 5hp Tec block would require a lot more than a pipe or a disconnected gov.
If it were that easy to get that kind of power boost out of removing gov, camshaft grinders would be out of business...starting a couple of decades ago.
vinco
I read a writeup on a 6.5 hp blue clone motor, where the author removed the governor and did little else outside adding a less restrictive air filter and exhaust header. He got over 12 hp out of it by doing just that. I figured it might help out on a tec 5 also.
ZnsaneRyder
Crazy Guy on a Bicycle
FL
12HP, I doubt it.
The clones do gain better than some engines because they flow good.
I have a clone engine, and it's reported with better intake and removed governor, you get around 8HP @ 5200RPM.
3600 is not enough, it's nice to be able to float it higher, as long as it's a good engine, it won't blow, and don't hold max for way too long. I've never had a problem running 5000+ And IMO 4000-4500 is a good safe high RPM range.
I doubt the tecumseh will have any problem with higher RPM's, just be responsible about it. Those kind of mods like intake, exhaust, and governor removal will help on just about every engine really.
Good luck with the mods! It's nice to get a little more out of it.
Raywelder
The Racers at heymow Do port polishing, straight pipes, better intake filter, and sometimes, Better carbs, and they either mill the heads down, or use heads of a slightly smaller engine. They do all kinds other stuff too.
Removing the gov doesn't increase HP, as Hp is a direct conversion from torque, However it increases RPM
