TC operation doubt + engine altitude questions.
not_a_bot
Tinkerer
Guadalajara, Jalisco, Mexico
Finally picked up my build form the Uni's workshop.
Say, after testing my trike for about 20 minutes, I kinda noticed this residue on my TC plate. Is this normal?
I'm using both the shaft spacer and a washer that was included to make the pulleys line up. Can you tell if I need adjustment?
As for the engine. I live 1566 meters (5,108 feet) above sea level.
Lately, our weather has been hot, around 35° C (95° F). I have this theory that the air we get here is not quite right for my engine. Someone mentioned air would be thin, causing a rich mix. He suggested to either get a high altitude jet (kinda new to all this so I don't have the foggiest idea of what "size" would such a jet be) or get a less restrictive air filter, seeing how, when my engine refused to start, taking out the air filter helped a lot. Taking into account karting is not a consumer hobby (as in, there's kart rentals but that's about it), specialized parts are hard to come by, and jets are not something I can easily buy, I'd like to give the air filter solution a chance first.
Any comments about this? I'll go the DIY air filter adapter, because shipping here costs more than the adapter itself.
KartFab
If the belt is too tight, the brass sleeve grinds down. Check the center of the engine shaft to the center of the jackshaft distance. Compare the belt number (numbers on belt?) to the required center to center distance on a 'comet 30 series belt chart' (google it).
Another less complicated way of testing this is to grab the belt close to the drive unit (engine shaft) and pinch it. There should be some slack in the belt -that picture does not tell me if there is slack or not in the belt. Enough slack to make the belt not even touch drive unit when pinched.
You are correct about the air/fuel mixture. From what I remember reading, you lose power because the air density is lower at high altitude, so you bring in the same volume of air, and same volume of gas, but the air is less dense, requiring less fuel.
However, I remember reading somewhere that honda (gx200/gx390 etc) engines do not really 'need' any sort of smaller jet unless the altitude is above 6000 ft. Yes you are close, but it should still run. I drove mini bikes/go karts in 7-8k altitude with no different jets and they did fine. I could tell I was losing power as i was climbing a hill over time, but it did not cause the engine to not run, just feels less powerful.
How does your air filter look? Is it new? clogged?
Also, on a sidenote, it looks like your chain needs to be spaced away from the torque converter back plate as you can already see where it has been catching on the back plate. This can wear, or cause your chain to break or pop off of the sprocket.
not_a_bot
Tinkerer
Uh oh. I bought it all as a kit. However, there's no such thing as slack. If anything, I gotta maneuver a bit in order to get the belt on. Now I'm worried.
The air filter, like the engine, is new, I forgot to mention that, as I haven't see you in my build thread. The engine must not have reached the 1 hour operating time mark, total. I do remember disassembling the engine at one point, and the ignition coil was bolted on without the use of gauge feelers, I'll fix that ASAP.
And about the chain marking the TC plate, yeah, had that at the begging, but it's been fixed since. Those scratches haven't.
Thanks a lot, your website and videos were a useful source when I was scrambling for info and tips.
not_a_bot
Tinkerer
And here are the markings on my belt.
Definitely not what I expected.
Distance between centers appears to be 6 11/16", adjusting for me taking a one handed picture while holding the measuring tape.
Some residue (belt shavings) is normal and to be expected especially if you are doing a lot of slow driving or start and stops or under any type of heavy load. The belt WILL stretch out over time but this will be minimal. The best thing I think you could do right now is drive it and enjoy the fruits of you hard labor and properly break in that engine. After it is broken in pull your spark plug and replace it with a new one. Drive it for one tank full of gas then pull the plug out again and look at it. If it is black than go to the nearest lawnmower repair shop and look for a smaller jet. If it is the color of dried grass or straw (tan in color) leave it alone. Do not modify anything until that engine is broken in though. ( at least 2 or 3 full tanks of gas run through it) :thumbsup:
not_a_bot
Tinkerer
Here is the belt chart. Find which one you need
Thanks! I had already checked it out but now other members can see it too. Guess I'll keep on rolling, and order the correct one for when mine breaks. It's pretty cheap, shipped to my country and all.
You are right, I'm the kind of guy that just can't wait!
I'll try and be patient, and break in this lil engine.
Thank you all, wonderful community.
