Predator 212 help!
Bmforrest1515
Parrish florida
So I bought a 1991 club car DS and a predator 212 motor. After finally getting everything situated on the cart, my motor is now giving me trouble. I never ran it stock, I instantly modded it to get a little more hp
to have some fun. So I added an aftermarket air intake from arc racing, a billet flywheel from arc racing, a vaccuum driven fuel pump tapped into the crank case, custom exhaust done by myself, and new jets and e tube. When letting off the gas the motor tends to backfire, it black smokes, and the spark plug is black and dry (rich?). I tried installing the bigger jets, it runs bad, tried the e tube, runs bad, tried a racing spark plug, runs bad, so I am stuck with stock jet and stock e tube. It also doesn't like to start, with choke on or off, not sure if this is an idle jet problem? Any help would be appreciated, and any questions I haven't already answered feel free to ask. TIA
Take a pic and post it using Go Advanced > manage attachments
Try to include the carb, pump, fuel lines, tank...
Probably need a T fitting and return fuel line to the gas tank from the fuel pump.
Fuel pumps can cause too much pressure for the needle valve / seat and cause flooding (rich mixture).
Not sure it will help, but I've recently learned this info with the help of a few knowledgeable people on here.
Ummmmm...BOB...HERE'S YOUR SIGN!!!!^^^^^^^
Well...yeah...you're running rich...you HAVE to figure out why!!! We'll help you as much as possible....and the ^^^^^ part of this post was because I warned Bob not to do a lot of modifications at once!
---------- Post added at 05:10 PM ---------- Previous post was at 04:51 PM ----------
a vaccuum driven fuel pump tapped into the crank case, a racing spark plug TIA
Ummm...that's enough...(taking you at your word),....first off..stick with stock spark plugs unless you're using racing fuel....( but you can't actually get away with that)...
What you CAN'T...is improper jetting...you're just TOO rich...unfortunately, the only solution is a heathy contribution to the Poboy fund!!!!!!
JIK..B back later....But. SERIOUSLY?
c
Bmforrest1515
Parrish florida
Thanks for the quick response! I do have the T fitting going back to the tank, I read that in a post before I decided to use the fuel pump. Here are a couple pics of my set up. Muffler is off at the moment due to some modifications and paint. Appreciate the help!
Jrgunn5150
Rudderless
You went all bob in your first post lol. Kudos!
I agree, you're too rich. Have you tried it without the fuel pump at all? Just to eliminate something?
Bmforrest1515
Parrish florida
It actually started before I installed the fuel pump. It also seems to run hot, not sure if that's a symptom of being rich? I had a 3/4" pipe coming out as the exhaust to a 2" pipe with muffler, just re did it to 1" pipe going to 2", not sure if that will help the heat problem but I'm sure it won't help the rich problem :thumbsup:
Joe-405
Enjoying New Projects
U.S.A.
Which jet and low speed jet sizes are you running ? I don't remember what plug I have but my box stock starts 2nd pull every time and I haven't even changed a plug since I built it 2 years ago for the buildoff.
If it's a .615 ruixing carb this will get you extremely close.........
Unrestricted .615 carb on gas: .038" - .039" with .021" -.022" low speed jet
Jrgunn5150
Rudderless
I'm running the stock jets ATM. I bought a #36 and #38 I believe and they just made it run more rich. Could it be that my new intake is more restrictive than the stock? Any ideas on how to tell if the carb float is stuck?
Take the air filter off and see if fuel is misting out of the carb. Something is choking it down. I have a 35 jet in mine with OMB filter and it runs fine.
Joe-405
U.S.A.
Turn fuel off.
Take fuel bowl off
Push float up til it stops
While holding turn fuel on
Let the float fall down
If fuel flows while down and stops while held up the float, needle, and seat are good to go.
Bmforrest1515
Parrish florida
is the .615 ruixing the stock carbs that come on them?
Joe-405
U.S.A.
.575 is stock usually. I worded that kinda weird. What I'm saying is that your bigger jet you have will work fine BUT the low speed jet has to be changed at the same time or it won't run. On the right side of the carb looking at it there is a little roundish plastic thing under the idle screw. This is the low jet.
The black thing is the low speed jet. It goes in the hole right below the Phillips head idle set screw in the pic............
Joe-405
U.S.A.
What size bit would I use to Make it correct?
Watch this first.........
https://m.youtube.com/watch?v=PstnywPGvNQ
Then if that doesn't work call arc racing and order a jet. They aren't that much and I refuse to drill my own. Cause it's cheaper to buy it then to buy the drill bits for drilling your own. And they tell you which jet you need also. They got mine spot on the first time.
Bmforrest1515
Parrish florida
Where do you find the specs he is seeing? It'd be interesting to see what the specs say they should be. I also realized that I had the #37 or #38 jet in instead of stock. Silly me:oops: but I plan on getting out and changing the jet to the #36 and read the plug and same for the stock To see how it runs then. Appreciate all the help guys!
