Keeping a Predator 212 quiet
jrm189
Hey guys,
I'm new. I've just finished my Manco yard kart live axle conversion, and now I'm tinkering with the engine. I'm super excited for this kart, as this is the exact kart I had growing up, and I always wanted a live axle like my brother and dad had on their kart.
I've been doing a lot of looking for low end power gains from a predator 212 on a yard kart used as a yard kart. I'm content with the power at the top end, and this engine will remain governed and with the stock exhaust. I just want a little more umph off the line. I've drilled my main jet to a .032, but with the stock air filter, it sputters and refuses to rev at all with a load. I took the filter and stock air box off, and just ran the carb open, and it ran perfect. Can someone get me in the ballpark on jet size with stock exhaust, and a K&N style filter?
Also, will advancing my timing 4 degrees help me out down low?
Lastly, would I be better served by buying a torque converter for the low end gain I'm looking for, or should i put my money in the motor?
Thanks everyone,
Jrm189
Well...you've obviously upset the A/F ratio and you need to rejet SMALLER! (Ummmm.....start over) no one can magically tell you exactly what sized jet.
Modifying engines isn't a pick and choose proposition....you can't open up the intake...and leave the exhaust stock...whatever extra you put in has to be able to get out!
What he said.
Its as if you are asking a Marathon Runner to only Exhale through a straw. But allowing him to inhale freely.
advanced timing ONLY affects the upper rev-band (well positive that is ;))
So if it's low end torque you're after.. don't!
And while technically a stinger pipe is the most obvious way to allow the engine to exhale freely.. it's not the only one!
From silent to loud I list just three more :
you can find yourself a big automotive exhaust (from say something like a small four cyl car)
it's likely designed for several times the combustion volume and will be unchallenged by the 212cc with only 3600rpms ...
and it's quiet ;) (as much as it'll be an ugly abomination on a go kart LOL)
Anywhoo.. it' still viable with some welding and such.
the stock exhaust of a big four cyl motorcycle should be a smaller package (reads nicer looking) and maybe still fit your bill
(but is most likely the more expensive option here)
the RLV muffler on a header pipe might be the most convenient way for you to get both an easier breathing engine and a "not too loud" result.
But truth is, the stock exhaust won't do you no good if you want to actually see some of the power gain you worked towards ;)
jrm189
I'm not ignorant to jetting. (I'm a motorcycle guy) I understand what I did made the mixture too rich. I guess to dumb my question down, is there a jet that's happy with just a K&N style filter, and stock exhaust. Generally, more fuel and air on the intake side with no change to the exhaust (as long as one doesn't take it too far) tends to lend itself to more throttle response and low end gains with no change to the higher RPMs. Does anyone have experience with only tweaking the intake?
Thanks
We'll see if you know anything or not....the exhaust sucks on a Predator 212...IT'S THE LIMITING FACTOR!!! One good look and you would know why!
Soooo..you can keep asking...but it's already been answered...it's up to you to absorb it! Adding on the intake side while leaving the exhaust stock AIN'T GONNA WORK!!!!
Is there another way you would like this put???? Or do you get it now?
This is not too loud, and it is better than stock.
It is just a stock ebay Briggs muffler, So only as loud as a typical lawn mower or roto tiller.
I think the pipe helps it exhaust and the muffler still muffles.
jrm189
So Kartman, what you're saying is, basically you've never tried it. You've never dynoed an intake only mod. You assume looking at something is investigation enough, and that all other options are stupid and I should just buy the bolt on HP because experimentation never led to anything good? Did I catch all of that right? So glad I hopped on this forum where the first guy to comment hasn't seen any lovin in a while. I'm out.
I've never been dumb enough to modify an engine to make it run worse! I may not have dyno'ed any engines...but I don't need a weatherman to tell me which way the wind blows. "Experimentation" ? Try performing a known and proven formula for failure.
Take your attitude with ya on the way out... :surrender: Poboy out!
Atlanta, GA
All snark and sourness aside, if you pull off a stock clone or predator muffler/exhaust, it is a little shocking to see the one inch wide exhaust port on the head and the 1/2" or so diameter hole on the exhaust pipe. Even a little work with a dremel tool can open up the stock exhaust.
Exactly what I meant by one look! Of course...lack of a dyno or lovin make you stupid!
Jeeze. That guy got scared off easy!
He forgot to mention the other 2 guys that weighed in.
A. Sid is a real smart guy, Gave him Options and backed up what Me and Poboy originally Stated
B. I get lotsa LOVIN, and I gave him more options for a mild pipe that is still quiet.
I have a stock Predator POS muffler sitting here. Cut off. but It is not worth taking pictures and loading them for such a snarky dude.
I'm done here! Some men you just cant reach
jrm189
I appreciate the other replies. The other guy rubbed me the wrong way. I've seen his "help" on other threads and I just didn't care for his attitude or condescending post. I am curious though why companies sell an air filter kit without the exhaust.
Also, doesn't the predator come jetted lean from the factory? If that's the case, wouldn't it be safe to assume that a fatter jet could help out performance?
---------- Post added at 08:49 PM ---------- Previous post was at 08:48 PM ----------
And Chancer, I wasn't talking about you with the lovin.
Because a lot of people fabricate their own exhaust....(not too tough) but nobody makes their own air filters.
Just be cool and listen...we'll help you!
Oh...and basically speaking....yes Predators are typically jetted lean...to compensate for the aforementioned crappy exhaust..so...yeah there may be a little room for improvement in the jetting department....and a filter upgrade...but don't expect much!
And...to kind of reiterate my responses...the ONLY way to determine jetting is through spark plug readings!
And....believe it or not...you've rubbed more than one member the wrong way here!
DHC
... I wouldnt say that too loudly... I may have to prove you wrong... Move up to 1:00~1:16... you can see the one I made... :thumbsup: Basically, its a aftermarket highflow filter housing (I made on a lathe), w/ 2 threaded holes on the inner part that holds the cover on. Uses a green universal heater filter, cut in a circle and clamped on w/ a hose clamp, to prevent it from possibly sucking into the housing/carb. The 'cover' is spaced off of the lip of the housing to allow enough air flow aswell as sandwich the filter in to prevent falling outta the housing, and diminishes the intake suckage sound... plus it matches the steering wheel :thumbsup:
https://www.youtube.com/watch?v=wj7A5QySHBk
However, on the subject of keeping the engine quiet... using the factory muffler, jetting up, and a highflow intake system... not probable (and I have tried numerous accounts/tries/attempts...). It is just NOT physically/mechanically possible to run (properly) a highflow f/a w/ a stock muffler. Any alterations to the stock muffler will possibly work... BUT will defeat the 'quietness' you seem to want.
Jrgunn5150
Rudderless
I would guess they sell the air filter without the exhaust, simply because they sell. I know I pieced all my stuff together, I didn't buy a "Stage Kit" or anything like that, I just shopped around.
If you're familiar with jetting, then you should also be familiar with plug reading? If so, I'd say buy some drills, and go to town to see what works for your combo.
FWIW, my pipe is about 4" long, and my neighbors don't complain. At least not to me lol. I ride it on the weekends, in the middle of the day.
