Medium sized flat rate box to N.C. is $13.
I'm going to ask him get it flat, if he needs to and then cut off an additional 0.025"
My best measured guess is I have removed ~0.010.
If he has to clean it up first to make it level??? We will give us an even wider window. Let's say he has a nice clean flat surface that has been already cut 0.005" to 0.0015"
If he cuts an additonal 0.025", we will be at 0.030" to 0.040" cut from original.
A deck height near zero, gasket thickness near 0.030", hemi head milled 0.030 to 0.040"....
Predator is 2.76" bore 2.16" stroke, the 214cc in this chart is close with a slight longer stroke. The 208cc has shorter stroke.
http://www.badassminibikes.com/GX200CompressionVer5.pdf
I should be safe on Piston 2 Valve clearance and increase the compression from stock 8.5 : 1, to a nicer ~10 to 10.5:1. Nothing crazy.
18cc head with +0.020" connecting rod and stock gasket would be right around 10.5 I believe. Seems to match up on chart and calculator
