Where is the blowby tube that was connected to original air filter ?
It got a bounty paper towel loosely wrapped around then electrical tape. Ordered a small filter but hasnt come in yet!
---------- Post added at 09:02 AM ---------- Previous post was at 09:00 AM ----------
oil is not blowing out. I wiped it off and no oil is coming out. The oil that came out did smell kind of like gas and was also slightly milky (and I mean slightly, not like water contamination)
would the engine be making weird noises if something bad happened or would oil just blow out somewhere and run fine until the oil went dry and burned up the motor?
---------- Post added at 09:25 AM ---------- Previous post was at 09:02 AM ----------
So i put it on jack stands and gave it half throttle. That would be about 3200 rpms after it spins up and the tires start moving.
If I open it WOT then I get a pronounced clicking tapping noise from inside thew crankcase
Might be the governor going bust. I havent removed it yet because im waiting on aluminum flywheel and new connecting rod!
---------- Post added at 09:27 AM ---------- Previous post was at 09:25 AM ----------
I might also add the oil level was perfectly fine and actually might have been slightly over filled. Even after the oil seepage i opened dip stick and oil overflowed out just slightly.
