Yeah but then what would we have to read about!!!:lolgoku:
Was just at HF looking at the 670cc. It would of been cheaper,
but then what would I of had to write about? lol
Maybe a bike engine/trans will go on the buggy
After I put this engine on my 2017 Build Off Contest Entry...:stir::lolgoku:
Don't you need one that WORKS for that???? Just messing with you!
2017! Boy talk about a Procrastinator! You still have a Full 8 months left in this years Build off. Come on Do it!
Then agian as long as it takes you to Build a perfectly Good engine!!!!
Maybe if I had a strong independent woman to do my welding and fund it, I would!
rk970
Coupeville, WA
Mikuni VM22..:stir:
Get some median strength contact spray.. like this
http://www.loctiteproducts.com/p/14...w/Loctite-Spray-Adhesive-High-Performance.htm
You can use it to glue down the sand paper... and it will peel off..
Either alternate directions 45° or do a figure eight motion.. do not push down really hard, do not reef down on the leading direction. (it will start to cut a bevel/radius).. It is hard to explain, its just like using the weight of your arms only.. Try not to do it all in one sitting, your arms/hands will feel like they are falling off..
Sorry to hijack... here is one of my little projects..
Chess with Friends...
I am
ChineseFingerTrapz
If looking for a match.
I'm worse at Chess than I am with engines. And slower too.
Jrgunn5150
Rudderless
I was at HF to get a Pneumatic punch this weekend, saw the 670, looked on craigslist, saw a "Project" GSXR 750 for 600 bucks, GF agreed the GSXR was a better deal lol.
Going to check P2V clearance using both modeling clay and degree wheel/dial indicator. Link shows dial indicator method.
http://www.camshaftshop.com/checking-piston-to-valve-clearance.php
This link shows clay method/dial indicator method. I bought the clay when I got the cam, but never used it.
http://www.enginelabs.com/engine-tech/engine-blueprinting-how-to-check-piston-to-valve-clearance/
---------- Post added at 09:22 AM ---------- Previous post was at 09:15 AM ----------
Not sure how easy dial indicator method will be with 26 lb springs??
Ignition Timing?
If this is TDC, where do I need to rotate the magnet to to find ignition timing? I've read right edge of magnet turned back to top edge of top leg of coil?? Is this correct? My timing is is off, or my method???
Right edge of magnet? Left edge of magnet?
Top edge of top leg of coil?
Bottom edge of top leg?
Top edge of bottom leg?
Bottom edge of bottom leg?
Regardless.....TDC is determined by piston position, not flywheel....With something that goes in the spark plug hole....when it stops going up....that's TDC.
EDIT: Reread post....IDK.... put a small bolt in the end of the spark plug boot....hold on to it and rotate flywheel....it'll let you know EXACTLY when spark occurs...you may be "shocked" to find out where it is .....LOL!
