TC and gear ratio doubts
not_a_bot
Tinkerer
Guadalajara, Jalisco, Mexico
Hello yall.
As some of you might now, I'm building a reverse trike for s̶h̶!̶t̶s̶ ̶a̶n̶d̶ ̶g̶i̶g̶g̶l̶e̶s̶ school, and now I have to define the whole engine/wheel mount.
I have a GX200 clone, 6.5HP, and bought this TC for it.
Packaging was great and it looks quality made. Bolted with minor complications (had to grind down an oil level cap, nothing unexpected as I had read about it beforehand, and the bolt that held the driver unit to the included was not the right size for my engine's output shaft, solved with a trip to the hardware store).
It engages as expected, units change ratios and it's pretty to look at.
Now, as I am still building the frame this will power, the engine/TC both couldn't have been running for more then 30 mins total.
My doubts are:
  1. What kind of grease/lubricants should be applied to the TC, if any?
  2. I'll use the #40, 10t sprocket. I have easy access to 43t and 40t sprockets. Can I get away with using a 43t sprocket on my driven wheel? Or is a jackshaft needed? Frame will be somewhat heavy because of rollcage and 12 gauge square profile tubing.
  3. If a jackshaft is vital, the combination I could get would give me a ratio of 14.22 or so (10 t on TC to 43t JS in, 13t or something close to it as JS out to 43t on driven wheel). Is this alright for me? Should I go higher/lower?
Considerations: Project is meant to be used on trails/light off-roading. I'd rather have low power end (climbing power, if I am not mistaken)
than top speed. Actually, I plan to get 2 rear wheels and place em next to each other. After the semester is over, I'll extend the rear (live) axle and make it a 4 wheeled thing.
If I'm missing anything else here don't hesitate to let me know as I'm a DIYgokart virgin.
Thanks in advance, I[ll go later today to get me some gears, chain, axle and related parts.
1) fresh out of the box.. likely none.. else dry lube (graphite) only INSIDE of the driver unit.
2) Nope, you say heavy, I say no (to 4.3:1 gear ratio that is).. think in the realmy of 6:1
3) can't tell.. to make a good estimate, we need to know the rear wheel diameter and the overall weight (a good assumption of it) of the kart incl the driver.
Then and only then we can give it a go.
you can -if you want- try my calculator yourself (open app.kartcalc.net on your mobile device)
not_a_bot
Tinkerer
What a nice little app!
Here's the output, assuming I do buy that tire I was eyeballing earlier.
KartInfo by kartcalc.net:
Code:
[FONT="Verdana"]
[B][U]KART[/U][/B]
[INDENT][I]Kartname [/I]: [B] Ouroboros[/B]
[I]RW diameter [/I]: [B] 25 in[/B]
[I]Weight [/I]: [B] 140 kg[/B]
[/INDENT]
[B][U]ENGINE[/U][/B]
[INDENT][I]Engine type [/I]: [B] Oakland [/B]
[I]HP [/I]: [B] 6.5[/B]
[I]Torque [/I]: [B] 12.86 Nm | 9.48 ftlb[/B]
[I]RPM [/I]: [B] 3600[/B]
[I]Governor removed [/I]: [B] false[/B]
[/INDENT]
[B][U]TRANSMISSION[/U][/B]
[INDENT][I]System [/I]: [B] TC & Jackshaft[/B]
[I]TC type [/I]: [B] series 30 6" driven[/B]
[I]TC sprocket [/I]: [B] 10[/B]
[I]Jackshaft in [/I]: [B] 40[/B]
[I]Jackshaft out [/I]: [B] 16[/B]
[I]Axle sprocket [/I]: [B] 40[/B]
[I]Final Ratio [/I]: [B] 10:1[/B]
[I]Lowest Ratio [/I]: [B] 27:1[/B]
[I]Highest Ratio [/I]: [B] 9:1[/B]
[/INDENT]
[B][U]PERFORMANCE[/U][/B]
[INDENT][I]Min Torque [/I]: [B] 115.74 Nm | 85.37 ftlb[/B]
[I]Max Torque [/I]: [B] 347.22 Nm | 256.1 ftlb[/B]
[I]Acceleration [/I]: [B] 4.44 m/s² | 14.57 fps²[/B]
[I]Top Speed [/I]: [B] 47.88 km/h | 29.75 mph[/B]
[/INDENT]
[/FONT]
How does it look? Should I proceed?
