the Rupp..
it has four wheels, a seat and an engine.. thus likely more power than a Torque Converter without a gokart or engine attached
Now, since the obvious thing's covered (Rupp being a go kart manufacturer and TC being an acronym for a Torque converter..)
the Torque converter has it's pro's
an additional gear reduction for a quicker takeoff, and (assuming we talk less than ~10 hp)
a 10% overdrive (meaning less gear reduction) in the top speed setting..
soo it'll be faster at top speed
and quicker at takeoff.
BUT you'll lose roughly 20% of the engine power using a TC (it's still worth it IMHO)
under racing conditions a TC desn't make any sense though (likely against the rules anyways)
and you'd want a racing centrifugal clutch instead (which is about as expensive as the TC
All things being equal, the Top speed of a bigger than series 30 TC and a cent clutch ..
so is the top speed (no overdrive)
On the other hand, having a TC installed allows for slightly higher gearing.. and we're back at more top speed.
