Two Stroke Mini Bike
Atlanta, GA
The details are the protein. The speculation is the fat, and there's plenty of that here. If you wanted or had time to provide more detail, I personally would eat it up.
NewbCarter
Solin , Croatia
The engine seems to be happy with the big muffler , at least while idling .
And there is something disturbing about hearing 2stroke noises from a 4stroke exhaust :cool:
Desertduler
You did not get it,the silencer that I am using on the mini bike is one that came with one of my race bikes which is a KTM 300 XCW which is a two stroke. See the expansion chamber? Look under the number plate on the rear of my bike and you will see the location where this silencer came from, it replaced the one that is on my bike in the picture which is a spark arrestor type silencer. I have two race bikes which may have confused you, the other KTM I have is a 540 four stroke which is a 525 MXC with a big bore kit on it making it a 540.
rushking19
Richmond Virginia
Yeah I can't wait to hear it rev nice exhaust set up going to sound very good , and y'all hear my exhaust set up soon :lolgoku: and mine actually is going to be a 2 stroke with a 4 stroke exhaust
NewbCarter
Solin , Croatia
Wops , thanks for the headsup ..
Cant think straight ... EFilI planning ..:mad2:
The details are great!
If you hang out here you can figure out how to build a Kart.
If you read DD's 2015 Build off thread.
You can see how to build a Kart. That will last and take a beating.
In detail with Everything thought of and improved upon.
Desertduler
I received the seat that I bought from a man that sells them on eBay, He makes reproduction seats for vintage mini bikes and such. I hate hand brakes other than a front brake on the right side of the handle bars just like a motorcycle and I just have to have the rear brake operated with my right foot so this is where the rear brake will be located on this mini bike, I have built a brake rod with a Heim end on the rod and I have attached it to the brake lever on the drum brake, I will machine a foot brake lever out of this 1/2 inch slab of T6 aluminum and I will use a sealed bearing for the pivot point on the brake lever. I hate the looks of this Azusa sprocket which I have of bunch of, so I will see if I can change the looks of it by boring some lightening holes in it. I am also making some rear axle adjusters so that the rear chain can be adjusted.
Desertduler
I spent the day doing some machine work to the components of My mini bike. Here are a few operations done on my mill. I milled keyways in the jack shaft for the sprockets and I started work on my foot brake lever, I started whittling away on material that I have saved for some time. I am glad that I kept it, good stuff!
Desertduler
I had some time to work on the rear foot brake lever today, I use super glue sometimes to attach parts together and check the fitment of them, I still have to finish the pedal pad.
So that pad is currently superglued to the arm. then will you be tig welding it permanent when finished. and are you going to machine some "grip" treads on the pad.
I know, I know... patience! LOL
Desertduler
I will not weld it, the pad will be screwed on with stainless steel counter sunk allen headed screws, I am not going to machine any grip treads in the pad, I am going put some grip on the pad a different way, you will see.
---------- Post added at 06:22 PM ---------- Previous post was at 06:22 PM ----------
Hey...Phil Shifty here! I recommend the "Handy man in a can!" Just shoot it with Flexseal..."that'll save ya thousands! "
Yup, that will do it! :lolgoku:
Desertduler
Here is what I am using as a grip surface, stainless steel 8-32 set screws that I can adjust for the amount of grip I need and also adjust for wear and or replacement if needed, I am going to make something like this for the foot pegs also. They are retained by Loctite.
