I'll look around tomorrow for a T fitting, a valve, and think of a way to return to the tank.
---------- Post added at 11:13 PM ---------- Previous post was at 11:00 PM ----------
What about a bulk head fitting in the top of the tank?
Jrgunn5150
Rudderless
I'd imagine that would work fine, it's basically just a dump.
So before I un-weave my beatutiful web of hoses or drill any thing into the tank, I wanted to run a little test. I added a T, and temporarily ran a hose back through the gas cap hole.
It ran better for longer, then the hose popped out and started spraying gasoline all over the garage.
lol - PROGRESS!!!!
---------- Post added at 01:05 PM ---------- Previous post was at 12:36 PM ----------
I imagine adding a 1/4 turn valve would be beneficial for a number of reasons including turning the return on/off and making the fuel pump somewhat adjustable.
OK what's the diagnosis Doctors????? lol
The exhaust is shaking my laptop and muffling the mic. lol sorry i'm not sorry lol
How does it sound it general?
RPM started at 2200 and continued increasing. Vacuum leak? Would make sense cause I've been testing and removing and replacing stuff. Gas Cap? Temporary right?
Some white smoke at 1:08. Think it was gasoline on the exhaust pipe??
About 1:45, I start playing with the throttle. And Scare my self at 1:50 lol.
Throttle response? 1:51 - 2:05?
Since RPM was kept low, what useful info can I get from Spark Plug Reading. Low Jet???
https://www.youtube.com/watch?v=gOiRFbw141E&feature=youtu.be
---------- Post added at 02:22 PM ---------- Previous post was at 02:14 PM ----------
I'm not crazy there's a buzzing that starts at 0:40, right? Only noticed in video.
---------- Post added at 03:13 PM ---------- Previous post was at 02:22 PM ----------
buzzing and craziness may not be related.
https://www.youtube.com/watch?v=_pFObyIOHcI
Jrgunn5150
Rudderless
Well, it sounds nice. Seems to be running well, but idling high. Do you have the idle screw set? Have you messed with it at all?
I didn't hear any buzzing, and Rolls Royce Aerospace just tested my hearing and color blindness lol.
I also didn't notice any white smoke.
Throttle response looks to be pretty phenomenal, but I only have my "Stage 1" Predator to compare to.
As for plug reading, I've only ever read a plug after WOT run's, I'm not sure what information you can pull from it now, other than a general, rich/lean idea. Did you change the plug before this run? If not, the results are going to be skewed from when you had it flooded before.
Yeah...plug readings HAVE to be done after a fairly long WOT run....
Idle...well....that's by ear....until it runs the best....see...main jets aren't adjustable, but sometimes, the idle is...(not always...)
Now...if you can start it up without a spark plug...then just get rid of it!!!!:rolleyes:
-Have not yet messed with idle screw.
-Next time I watched, thought it started when the (EDIT) VIDEO did (but maybe crazy, lol I didn't hear in live)
-The smoke was for real, but not much and just a few seconds (There was a harmless gasoline fight 'tween me and the Predator! I'll win the easy battles when I can! lol)
-Same plug I kept flooding with before.
Thanks for all the help. Much Appreciated.
Hopefully I can get the return line situated, everything sealed up and torqued down, and start playing with the carb. :wai:
Dates, vacations, engine parts, tools, and even car insurance on top.
No work for almost two weeks has me too broke to pay attention.
I'd like to order just a TC bushing (maybe I will), but also like to order extra stuff so I can loose it before I use it and combine shipping.
Learning the Carb will keep me busy for a bit, while I put together hopefully a final shopping list. :smiley_omg:
Jrgunn5150
Rudderless
Well now that you have it fired you can get it ran in, tuned in, etc.
My life is a constant battle between having money for all my cool stuff, (kart, C10, F100, Fj Cruiser, Rc car's), and time to do it because I'm not at work 12 hours a day lol.
Played with the idle screw. Found out the wire clothes hanger I used was too thick or too long (where it attaches to the butterfly). It gets caught behind the pivot. I'll have to shorten the end that goes though the black plastic connector.
Jrgunn5150
Rudderless
I had to make several iterations of my coathanger throttle linkage. Even after I had one I tested flawlessly in my dining room, somehow it changed in the driveway lol.
I cut them all up for linkages and exhaust hanger's, i only have plastic now :cornut:
Do you know how hard it is to Find a "Linkage Hangar"???
Unless you have uniform service at work or you are Yuppie enough for dry cleaners. Good Luck.
It is even harder to find the realyl Good "Marshmallow roaster hangars"! LOL. :sarcasm:
Jrgunn5150
Rudderless
They have uniform service, and even though I am in engineering, I get uniform colored shirts lol. But they have some type of different hanger, not the bronze colored one. It looks stainless or something, it's not very sturdy though, I tried to make a linkage out of one lol.
Mine was the hangar with that Green crap on it like a Framing nail. Works great for a linkage!
For Marshmallows, you have to get it red hot to burn off that green crap. Then it is safe for "foodservice use" :roflol:
Try being basically bedridden for a month and a half!
Sorry buddy, sounds terrible.
It was...I'm 6' tall....always been thin....but when I start dropping below 140 lbs. I get pretty weak...and I've never spent that long inactive...soooo...getting up and moving around was quite an experience...I got wore out and sore really quick...
Doing better now....put on 10 lbs. in the last week or so
...and my body is getting built back up....but...this was almost as bad as going through Cancer treatment! (The Cancer treatment was VERY hard on my body, ) but I was NEVER bedridden...even though eating was almost impossible, and I dropped. from 180 to less than 140 in about a month....
Ok, took out the wire hanger, gave it a circumcision, re-installed it. NOT the problem. Said my return spring must be a tad to long, I'll drill a new hole, I said. When I removed it, I realized it was NOT the problem.
It just doesn't return all the way to the seat. It will only go so far back, the screw must make up the difference. lol
It was fine before. lol
---------- Post added at 01:15 PM ---------- Previous post was at 12:56 PM ----------
I've been taking notes. lol
Lets see If I got the idea right behind the Idle Mix and Fuel Screw.
The fuel screw only affects the Idle Mix. Adjusting it can alter Idle RPM, cause stumbling when hitting the throttle from idle, or cause hesitation in the throttle response from idle.
LEANING out a RICH IDLE mix by turning the FUEL screw IN should INCREASE idle RPM and fix throttle stumbles?
If throttle response if poor and there is a hesitation, then it's too lean?
ENRICHING a LEAN IDLE mix by turning the FUEL screw OUT should LOWER idle RPM and fix poor throttle response.
If giving gas and it stumbles, it's too rich.
If Fuel screw setting is less than 1 1/2 turns out, the Pilot Jet is too big.
If Fuel screw setting is more than 3 turns out, the Pilot Jet is too small.
---------- Post added at 01:21 PM ---------- Previous post was at 01:15 PM ----------
So what I'm looking for is an idle around 1800 RPM, no stumbles, and instantaneous throttle response.
Goals.
