Why Won't It Run?
gokarttimmy
Pittsburgh,Pa.
001.jpg Okay...got a 212 Predator.
Engine is getting fuel from gravity feed carb set up.
Brand new RuXing carb out of the box.
Runs on starter fluid for a second, but doesn't want to run on gas.
I hooked up a redneck electric starter with a drill and socket to save my hands.
It fires once and that's it, without starter fluid.
Everything seems to be assembled correctly.
Is there something obvious that I have overlooked?
Thanks for any input.
leesiel
Yardcart 196
Savannah G.A.
I've read on here that even New carbs can have trash in them from the manufacturers! Take it apart inspect and clean as if it were used heavily. Had to boil mine three separate times to get it right.Remove the fuel line from carb...if gas flows from the hose then the carb is problem.
ChromeRhino
Gotta make sure the float bowl is full of fluid. Might have got an air or vac lock. And check to mske sure your vent ca p is working. If that cap won't vent the fuel can't escape. Try to run it with the cap off. Oh, and you tried cyssing at it already, right? That's an important step in the family troubleshooting procedure.
Good point!!! A blocked vent hole has caused problems in the past, and removing the gas cap is a quick and easy check!
gokarttimmy
Pittsburgh,Pa.
I tried starting it with no cap on-still won't go.
I wonder if I have put it back together wrong.....First, a paper gasket-then the black plastic wire loom-lookin' thing-then a green paper gasket-then the carb-then the rubber/steel gasket-then the air cleaner adapter. Did I miss a gasket somewhere? Also, could the coil or ground wires be anything to think about? I have a feeling it needs one more gasket or something. When I unscrew the float bowl screw (the one you change jets with) gas comes out, so it's getting gas, apparently.
It just seems like there's one thing that needs addressed and it will go like a bear.
Jrgunn5150
Rudderless
I wonder if I have put it back together wrong.....First, a paper gasket-then the black plastic wire loom-lookin' thing-then the carb-then the rubber/steel gasket-then the air cleaner adapter. Did I miss a gasket somewhere? Also, could the coil or ground wires be anything to think about? I have a feeling it needs one more gasket or something. When I unscrew the float bowl screw (the one you change jets with) gas comes out, so it's getting gas, apparently.
There's a gasket that goes between the carb and the plastic piece as well.
Kelly Wood
The Mad Kartist
Salt Lake City Utard
Dumb observation concerning your pics... the Choke. It appears to be on... move that lever forward. Both of those levers should be forward for typical running.
cavfire
auburn, georgia
Cone filter and pipe installed? Jetting could be an issue, although they will normally run albeit lean. From what I've seen these motors will run pig rich, lean not so much though. Worth looking into the idle mixture screw as well, factory is somewhere around two turns out. Try backing it out 1/8 turn at a time. If that doesn't help go in 1/8 turn at a time, and it's good practice to know where you started at before any adjustments. Kelly's observation on the choke is a good one, as soon as you get it to fire start opening up the choke and see if that helps.
Another thing that comes to mind is the butterfly. If you recall when the governor was installed it holds the butterfly open when not running. I'll normally hold my throttle open when I start my motor, starts easier that way. As soon as it lights off I close the throttle and open the choke.
zbuck
Ft. Wayne, IN
:wai: Looking at picture number 1, I do not see any fuel in the filter. Does it have a fuel shut off, if so is it open? There should be a fuel bowl drain. Open it and see if fuel is getting to the carb.
ML-TOYS
long island, new york
Yeah i was gonna say that the thing is empty, cant run if theres no gas getting thru
