Please tell them I helped you...because...they all think I'm just a prick....AND THEY'RE RIGHT!
This prick is a pretty good guy!!! I PM'd this morning and asked for help because I respect and value his knowledge and experience. I was afraid I had no compression and I was ready to take the head back off and cry again. lol
He reminded me that it would be difficult for even me to mess up the compression that bad.
He said, "try the original spark plug and shoot some carb cleaner up in that *****"!
Thanks Poboy
---------- Post added at 04:42 PM ---------- Previous post was at 04:38 PM ----------
R - Rated Sopranos Clip
https://www.youtube.com/watch?v=NyT94FvvIQc
I tried 1 more time. Choke open, maybe 1/8-1/4 throttle.
Started right up on first pull.
Kept it near 2300-2400 RPM.
Ran ok for about 10 seconds and died.
Within a sec or two, I cracked open the carb drain and gas came poring out.
Similar to the video I posted earlier.
Fuel screw is two turns out. If I had to guess, its rich??? Not sure that has anything to do with it running for 10 seconds then dying.
Off to work, thanks again!
Jrgunn5150
Rudderless
That sounds like pressure, or delivery. Are you running the external pump below the carb still?
No, it's actually zip tied to the fuel tank
---------- Post added at 07:09 PM ---------- Previous post was at 07:08 PM ----------
Page 9 post 178 is the pic
Jrgunn5150
Rudderless
That looks very complicated lol. Is the pressure adjustable? I looked on their site and didn't see anything on it.
I wonder if you are over powering the float and flooding it.
So happy to hear you got it to run.
Carbs are one thing, but congrats that your engine work is Fine so far.
I been watching and learning, So sorry i had no good advice.
But thanks for sharing I think I learned something.
I never noticed your sister smelled like Provolone!!!
It is complicated. Lol
Hard to leave clearance for the throttle to move freely.
Pressure on pump?
I don't think anything is adjustable on it.
Jrgunn5150
Rudderless
Pressure on pump?
On the pump, correct. Probably not, I was hoping lol.
Can you go back to your 212 Carb for break in/tuning? Perhaps then you can add in the new 390 carb, then the fuel pump individually to isolate the issue.
Should I try gravity feeding the carb?
---------- Post added at 07:52 PM ---------- Previous post was at 07:52 PM ----------
Then go back to original?
I do not remember how you did yours.
One trick I learned for 2slicknick DHC (I think)
In The supply line to the Carb, install a T. and send one leg to the carb and the other back to the fuel tank. It keeps the pressure from overriding the needle and flooding the carb.
I've read about this before but skimmed over cause it didn't apply yet.
Sounds reasonable!
It worked for mine.
I would ride for like 1 minute, Flood and stall,
Restart 30sec.
Restart 10 secs
Then would not start.
So I did this and it worked, Sort of....
I had to put a vice grip on the return line to start the engine, then remove it to Drive. (shrugs)
So I ended up switching back to Good ol gravity.
Maybe a T and a valve
---------- Post added at 08:24 PM ---------- Previous post was at 08:07 PM ----------
Oh lord, more hoses! Lol
Exactly! I got a little brass T from the local Auto parts.
And I have a plastic tank so I got a straight barb fitting, drilled a hole in the tank and threaded it in.
