NewbCarter
Well , the plans to get a mikuni carb and finally get this engine running kinda went kaboom ..
So im thinking ... i have a Arduino kit coming my way .. why not convert this engine to EFI ?
After all .. EFI kits from the likes of ecotrons go for up to 600$ ...
For those who dont know what an Arduino is , its basically an open-source platform that revolves around inexpensive electronics , coupled with some #C language knowledge , you can make pretty much anything .
So here is the plan :
- I will use a ATMega328 microcontroller chip , which has 13 digital pins ( outputs or inputs ) , and 6 analog inputs .
- For ignition timing / RPM measurement and injection timing i will be using an NPN Hall Effect magnetic sensor
- For temperature indication i will use 4 K-Type thermocouples coupled with MAX6675 ADC modules , to convert the given analog signals to digital ones.
- Im yet to decide on how to get pressure readings ( intake ( MAP) , oil pressure for an eventual turbo to come , and fuel pressure )
The white / blue circles are points which are to be drilled and tapped to accept the K-type thermocouples . The blue sketch near the engine crankshaft is the way im going to mount the magnetic sensor inside the flywheel radius .
Since the sensor is threaded , i can adjust the pickup to make fine adjustments to the ignition timing .
Links to sensors / Arduino kit :
http://www.ebay.com/itm/New-Hall-Ef...634490?hash=item4aea4f21fa:g:uq0AAOSwrklVWiZF
http://www.ebay.com/itm/MAX6675-Mod...924042?hash=item5d517a3d0a:g:DFgAAOSw~1FUVKpW
http://www.ebay.com/itm/Sintron-Lig...755808?hash=item2a2df68020:g:yuUAAOSwKrhVZSBv
