I'm looking to build a sprint style go kart. I'm planning on using a genuine Honda GX200 and at least modifying the air intake and exhaust. Not sure if I'll remove the governor and use 18lb valve springs as well as a different flywheel but I'll cross that bridge later. The kart is going to be built from initially 1" x1" x11 gauge steel square tubing (may do an Aluminum Alloy frame later when I can get a spool gun). My guess is the frame will weigh about 100lbs with myself being around 160lbs. Gears going for a 14tooth clutch and a 54 tooth main sprocket. Goal speed is about 30 with possibly going upwards of 40mph later.
My questions are being as this will be on the street and probably will not see a go kart track ever should I use a clutch or can I use a torq a better like a 30 series? Planning on using a Chrome Moly live axle and 11" Hoosier or Firestone slicks/ribbed tires as well as a disc hydraulic brake.
With what I'm planning on doing and engines mods will the engine have enough power for what I'm wanting to do with a clutch or should I go with a comet 30 series? May mod gov to allow upwards of 4200rpm at most.
