clutch extremely hot problem
NotSoMasterMind
South lyon michigan
i go my go kart to move, (i am new to this stuff) but the clutch gets extremely hot to the fact that when i put snow on it, it melts in the blink of an eye, is this supposed to happen? i have a 13hp honda engine, witha heavy duty 14t clutch and a 60t sprocket....thanks!
edit* but overall, is there any way to cool my clutch down?
Kelly Wood
The Mad Kartist
Salt Lake City Utard
What kind of clutch is it? How about some pics of your ride? I'm sure we can help.
Clutches tend to get hot when they slip A LOT. Means lots of things but let's get some details from ya.
I think just posting a pic of your ride may aid in initially answering the question... and the kind of clutch... and it's age.
Mental note: Don't put snow on it when it's super hot, it may warp it and then... you may have more issues and... subsequently, another visit to the docs office (here) :)
rocketkart
florida
:iagree:
Kelly Wood
The Mad Kartist
LOL, I forgot one thing. You get a lollipop every time you come back and you've done what we said. Well, some of us that is.
Really! Have fun, we're a fun bunch... well, some of us that is.
You didn't mention tire size....but right off the bat....with a 60 tooth axle sprocket....your clutch should have no more than 10 teeth.
For 14: 14×6= 84....soooo....your axle sprocket is 24 teeth (at least) too small. Yeah, your clutch is gonna get hot, and die young.
Kelly Wood
The Mad Kartist
Come on now, let's not give the wrong info.
In the race world with 4 cycle engines, it's quite normal to have an 18/60 something combo...and the clutch does get hot. (track dependent of course)
I've done 19/52 as well, not uncommon either in the karting realm. (jr 4cycle classes)
Sure, it's probably a yard kart in which case you have a good base for neighborhood goofing off...(and maybe 25 mph) but... we don't know what it is yet, let's just wait here and see what he adds.
nomastermind? what ya got?
NotSoMasterMind
South lyon michigan
18 inch tires, but is it really that bad that it gets that hot that quick? i took it for a small test drive, and the chain hopped... alot.... but thats because of the loose chain. but are you saying that i need a bigger sprocket in order to get the clutch not as hot? because it is a go kart that is supposed to be ridden on the road/dirt, so i wanted acceleration and speed...
---------- Post added at 10:32 PM ---------- Previous post was at 10:30 PM ----------
i cant get pics for atleast 3 days... but does it help that it is a 1inch bore, and it is a heavy duty clutch witch 18 inch tires. (from a quad)
---------- Post added at 10:34 PM ---------- Previous post was at 10:32 PM ----------
got a 390cc (13hp) honda engine, your right, it is a onroad (60%) offroad (40%) and yes, i have a big naborhood with a couple fields. so acceleration and speed should be good. btw: estimated to go around 40mph, estimated on a sprocket caluculator.
---------- Post added at 10:41 PM ---------- Previous post was at 10:34 PM ----------
also how long will my clutch last if it gets that hot.
14/60 on 18"... yes that is BAAAAAAD!
it is very likely that your clutch will not live on to see this spring I'm afraid.
you should at least run 7.8:1 (assuming your kart is not heavier than maybe 300 lbs with you in it)
that means we talk about a 109T axle sprocket already...
PS oh to be clear.. those numbers are calculated.. not estimated;
very conservatively I admit, dialing towards reliability instead of speed, but still calculated ;)
NotSoMasterMind
South lyon michigan
the kart is about 210lb with me in it, 20lb for the kart, 60lb for the engine, and 115lb (im only 13) but what if i dont ride it aggressively, also what if i get a radiator, or some way to cool down the clutch (do you have any suggestions) would that make the clutch last longer?
Your clutch won't last that much longer, with that ratio...
Your tires are big and relatively wide... So more surface area... So more importantly does the ratio needs to be more in the ideal tooth range.
6:1 is the ratio to aim for.. Bring it to 8~9:1 won't hurt..
Depending on the kart... A jackshaft might be the ideal modifier... Least it allows a quicker way to change out sprockets if nessisary.
Edit: Sid beat me to it first...
NotSoMasterMind
South lyon michigan
Depending on the kart... A jackshaft might be the ideal modifier... Least it allows a quicker way to change out sprockets if necessary.
by ratio, do you mean clutch divided by sprocket?, and the dimensions are about 18tall, and 4-4.5 inches wide, idk the height, it might be close to 16-18 and again, i am new to this.... jackshaft?
---------- Post added at 11:43 PM ---------- Previous post was at 11:29 PM ----------
but final question.. would a radiator help with the heat, and prevent the clutch from as hot/ getting destroyed
rocketkart
florida
there is no such thing as a radiator for a go kart centrifugal clutch, not that i'm aware of anyway. ratio is your gearing, the gear ratio is defined as as the input speed relative to the output speed. example, if you have a gokart with (18 inch tires output speed) and 60th sprocket and (12th on the Clutch input speed) it is Calculated to do a top speed of 39mph. now if you have a gokart with (6'' tires output speed) and 46th sprocket and (12th on the Clutch input speed) it is Calculated to do a top speed of 17mph. the only thing is, if you go to high/bigger in the Diameter of your tires and more Teeth on your axle and more teeth on your clutch the more torque/power you are going to need to spin all the big stuff. the way i see it is you have 2 option. add a jackshaft and lose some speed or get a torque converter. every centrifugal clutch will get hot, **** i seen a few glow red at night time riding, but it seems to me and the otheres here that your gear ratio is off and your centrifugal clutch being heavy duty or not can only take so much and will probably fail on you in the near future.
Well yes and no..... a jackshaft will allow some compound gearing, thus there isnt as much strain on the clutch.
A jack shaft is a rod with bearing supports and 2 sprockets that compound the gearing , allow a direction change of a driving chain or offset the axis of the driving chain...
Hers my bike and a few shots of the jack shaft I have to make the bike right side drive...
http://www.diygokarts.com/vb/showthread.php?t=5461&page=6
NotSoMasterMind
South lyon michigan
but my chain is on the right side, and so is my driveshaft, there is no reason for my to switch the sides.
NO....the main point of why jackshaft is being repeated... It allows compound gearing.....
and other options....
My bike has a large rear tire.. A spare car tire. This has a large 24" OD. Now aside of a few engineering details(the right side drive), I needed the jackshaft to modify the gearing from just having a chain to the clutch to the rear tire.
In you kart. you have a tall rear tire, and a burning clutch. adding a jackshaft to modify the gearing set to accommodate those elements, to reduce strain on the clutch.
Off hand..... some numbers I just through out there...
14-24-14-60 =7.347:1...... thats a start...
Heres the ratio calc...
http://www.affordablegokarts.com/GearCalc.php
We also need some pic on what were dealing with?
