max torque clutch and proper ratio?
cody.ross
Half moon bay California
I have a invader go kart that i just purchased for $400 with a predator 212. Heres my problem (s) the clutch engages when theres no weight on it but when i sit on it and go full throttle its doesn't catch at all and with and without weight it makes this noise. Ive tried getting all the lubrication off and letting it dry but it still makes the noise and doesnt catch it's a 13 tooth max torque and the sprocket is a horseman 64 tooth. Back tires are 6.00x11.00 also. When i bought it he said the clutch is new and it looks very well new and clean. When i took the o-ring off it wouldn't come off. Hope someone can help. Really need these answers
Optimal starting point gearing ratio is ~6:1, so in this case at least a 72t rear sprocket is a better deal, or you will need a jackshaft to compound the gearing to get that.
However, ground clearance will be a factor as the sprockets take quite a bit of that, so you might need a jackshaft anyways.....
Cant really tell, no pics.
Ground clearance? A 72 tooth #35chain is 8 3/4" Your tires are 11". So 11"minus 8.75" is 2.25" divided in half leaves you with only 1" ground clearance.
and a 72 tooth with a 13 clutch still just barely gets you to 6:1 It is actually 5.5:1
Your current set up is 4.9:1
What I would do is try a 12 tooth clutch, It sounds like your current clutch may be trashed any way. The 12 tooth will get you 5.3:1 Worth a try and you can get a clutch for like 20 bucks on ebay. I run 6:1 on 15" tires so with your 11" tires I think it will work.
All this is assuming you have #35 chain.
Yup, your ratio is a bit tall, but it should get you moving with tyres that small. Does the clutch get hot and smoke when you are sitting on it trying to get it to move?
cody.ross
Yeah it smokes so i ordered a 10t to get me to 6.4:1 im not sure of my chain but i figure the 10t should more than do it. Also I'm thinking the carb might need to be cleaned because when i turn the choke off it revs a lot higher and sometimes when i give it gas it does nothing. Will the 10t be a good fit to the 64t? Ground clearance is about 1 inch so there's not really any play there
number9
KY
Do you know what chain size you are running? A 10T clutch is available in #35 chain, but you have to look for them. If you just hypothetically told a local hardware store to "order a 10T clutch for a go kart", it likely would be for the larger #40 chain and not work.
Have you lubed the clutch at all?
cody.ross
I'll have to check. But i have tried lubrication and still nothing so idk what to do if someone could please text me so i can ask direct questions i would love that most (6028855896) but ill get back on the chain
