Generac motor help
Toycrusher
Deep Deep South Texas
Picked up a 15 hp Generac from a generator. Anyone have any experience with these? It has a tapered crank but they make a 15 with a 3/4" straight crank. Anyone know what's involved in swapping cranks? Other suggestions?
rocketkart
florida
you will have to spit the case/remove side cover of engine. than unbolt the connecting rod from the crank. you will also have to remove the flywheel and flywheel nut. with the new crank use a torque wrench for torqueing down the connecting rod to the crank !!! this is critical to use a torque wrench or you can really mess things up. the torque spec should be around 10 to 15lbs cus i just did a 13hp honda engine not to long ago.
Find a different engine. The tapered crank will not accept any clutch or torque converter.
Or change the engine crank. Not worth the effort.
Toycrusher
Thanks. I wasn't particularly specific in my questions... does anyone know if the generac would be considered a clone engine or if it's an independent design?
I'll be tripling the power on my mini monster truck so I don't suppose I would need any performance parts...
Other question, the alternate crank for this engine has a 3/4" shaft while it seems other 15 hp engines use a 1" shaft. Would it destroy my 30 series converter if I did manage to get it on?
Yes it would..... absolutely. You need a 40 series for that amount of hp
Toycrusher
And i need more help...
#1- How do you open the crankcase on one of these? I got the front half of the motor loose and I can get it up about a 1/2" but then it won't go any further like something is holding it. Do I need to pull the governor shaft?
#2- I can't seem to find the bolt pattern specs for a 40 series torque converter. Can I even get one on this engine?
#3- what is the normal length the 1" shaft needs to be to mount the 40 series converter? I'm considering taking the crank to a machine shop to have it built up to 1" and a key cut into it...
Toycrusher
So I answered some of my question. It has the 5" bolt hole circle which fits most converter plates I see listed... but... does anyone actually make a mounting plate system for the 40 series converter? If not, how would I actually manage two jack shafts? One to set converter belt tension, 2nd from converter output to main jack shaft, and then to axle?
Shaft length. Only thing I could find online was that the motor shaft needed to be 3-7/8" long. Is that correct? Are there different 40 series drivers?
Finally, I CAN'T GET THE DUMB THING APART! :mad: The front cover raises about a 1/2". I look inside and don't see anything holding it, the governor gear stays with the cover, the camshaft and balancer shaft are staying in the block, it's like i'm getting hung up on the crank seal but that doesn't make much sense. What am I missing?
Toycrusher
Ok, got it open. there was a light rust buildup on the crank I couldn't sand off with my dremel and that was getting caught on the crank journal. I'm not real proud of the scratches made but I don't think they'll affect oil pressure any.
I removed the governor... just for fun. :devil2: Hopefully valve float kicks in to hold the 15hp together like it does on the smaller engines... :worried2:
