3.5-4hp with a centrifical clutch
Subnet76
Just got a new cart with a 4hp Briggs. Was told its a 1986, model 111707. The cart has a maxtorque centrifugal clutch. It seems like the clutch starts to engage but doesn't if you push the cart it will get moving but if you hit a hill it slows down, to a stop. I know its not the clutch its brand new! Could it be the motor does not turn the RPM's? Any ideas to what may cause this?
r_chez_08
Should be in the shop...
Cornwall, UK
clutch might not be engaging fully? i think i might have the same problem when my kart is finished.
Kaptain Krunch
Pro Junk Collector
vermont
Hillard clutch? same here, when i was still using a crappy industrial engine (never use a dirtbike engine in a go kart unless your willing to give up clones) and it slipped like crazy, i think it never fully engaged.
